Radiator first fill from dry - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By PSk
post #1 of 15 (permalink) Old 11-29-2016, 03:45 PM Thread Starter
r-mm's Avatar
Getting ready to fill the radiator from completely dry. The 2000 GTV spec book says "about 2.5 gallons" of "Alfa" coolant is needed. Can someone help me here - will standard 50/50 do the trick? I'm guessing the radiator alone won't swallow 2.5gallons and the waterpump needs to run in order to bring some of that into the circuit? Do I fill the radiator as much as I can and then keep an eye on it after first start?
'73 GTV bare metal project
E30 Daily - '65 912 project in waiting
r-mm is offline
post #2 of 15 (permalink) Old 11-29-2016, 05:56 PM
Nakagtv's Avatar
This is how I did on mine:
-Unscrew M6 bolt on top of the water pump
-Unscrew brass bolt on top of the manifold, by the thermostat
-Start filling the radiator until coolant starts to flow out of the hole on top of the water pump. Put back the screw and fill the radiator to the top
-With small funnel or a squeeze bottle keep filling manifold
-Squeeze on hoses to move any trapped air, keep topping off radiator, manifold and expansion tank
-Put the brass bolt back on manifold
If your head gasket is new and head bolts need to be torqued down after the first run: DO NOT tighten the radiator cap all the way, you don't want pressure in the system yet. RJ suggested using only distilled water for the engine break-in
Hope this helps
Zaza
Refreshing 1970 Euro-spec GTV 1750
Nakagtv is offline
post #3 of 15 (permalink) Old 11-29-2016, 06:11 PM
65Sprint's Avatar
I wouldn't fill the cooling system with the antifreeze/distilled water solution (50/50) until you have run the engine and confirmed you are leak free. Regardless, fill the radiator, run the engine, and loosen the bleed screws to purge any air. Top up the radiator as required. Suspect you will get 8-9 quarts (at least) in the system prior to start up.
Rich Hanning
65Sprint is offline
post #4 of 15 (permalink) Old 11-29-2016, 06:19 PM Thread Starter
r-mm's Avatar
I have just under two gallons in there using Nakas method. Need more or just more distilled water. You hesitate on the 50/50 for what reason.
r-mm is offline
post #5 of 15 (permalink) Old 11-29-2016, 06:22 PM
Nakagtv's Avatar
As I understood antifreeze is "slicker" than water and seeps in between the head and gasket easier
Zaza
Nakagtv is offline
post #6 of 15 (permalink) Old 11-29-2016, 11:49 PM
PSk
Importantly when you first run the engine up to temperature have your heater turned to full hot AND the radiator cap off. Do not put the radiator cap on until the engine has burped and the thermostat has opened.
Norseman50 likes this.
'71 1750 Series 2 GTV:
PSk is offline
post #7 of 15 (permalink) Old 11-30-2016, 06:31 AM
Nakagtv's Avatar
Knew I was forgetting something. The heater!!!
BTW had two brand new plastic heater valves leak after few runs (from 2 different suppliers). Ended up opening them and adding some Permatex Ultra Black on the edges around the seal. It's been 2 years and still no leaks.
Zaza
Nakagtv is offline
post #8 of 15 (permalink) Old 12-04-2016, 02:19 PM Thread Starter
r-mm's Avatar
I found this posted by RJ - any idea what the problem with Bar's Leak is?
"As well break in period should be done with water only, (no antifreeze) and I use one tube of powder type leak sealant, not Bars Leak."
r-mm is offline
post #9 of 15 (permalink) Old 12-06-2016, 07:43 AM
GTA R's Avatar
Bar's Leak is a radiator sealant, old, old school. I remember when I worked at International Harvester in Doncaster in the 70's, they used to put a Bar's Leak pellet in every new radiator, just in case.
I never had any success with it. They do fluid types now, as well as the pellet.
New in the box, it looked like something the dog has done, and quickly got that nickname at work.
I prefer to use nothing until there's any sign of a leak, then I use Radweld (fluid solution. Don't like any form of bodge really, but Radweld is good to get you home.)
Not seen Bar's leak in the UK for years, but still available for you boys at Walmart :-
https://www.walmart.com/ip/Bar-s-Lea...-Leak/16888773
Steve
GTA R
1963 Giulia Ti Super Rep almost finished.
GTA R is offline
post #10 of 15 (permalink) Old 12-06-2016, 08:18 AM
I have seen bottles of Bar's leak in several race car trailers but I have never used the stuff.
85 GTV6 3L
alfaparticle is offline
post #11 of 15 (permalink) Old 12-06-2016, 03:30 PM Thread Starter
r-mm's Avatar
I gathered, maybe incorrectly, that RJs suggestions of plain water and powder sealant are geared to preventing headgasket leaks on first startup more than cooling system leaks, yes?
r-mm is offline
post #12 of 15 (permalink) Old 12-06-2016, 05:24 PM
65Sprint's Avatar
Of course the best way to find out is ask RJ. Short of that, I wouldn't use anything except water (distilled) for start up as suggested above. As long as you have an "approved fluid" in the cooling system, what is, to the nth degree, is not critical. If you "feel better" starting out with a 50/50 mix then do that. It just makes more of a mess than water if you do happen to have a leak.
Rich Hanning
65Sprint is offline
post #13 of 15 (permalink) Old 12-29-2016, 07:38 PM Thread Starter
r-mm's Avatar
Guys I'm going to be running her up to operating temp this weekend. With a first-time idling engine and a lot to look out for, what is the clearest cue that it is 'safe' to put the radiator cap on?
r-mm is offline
post #14 of 15 (permalink) Old 12-30-2016, 02:17 AM
PSk
First of all I would not let a rebuilt engine idle, I'd raise the revs up to 2000 rpm and keep it there. Check oil pressure, for leaks, turn heater on to full hot, etc.
It is safe to put the radiator cap on once the thermostat has opened (the top radiator hose will get hot) and she has burped.
Good luck
PSk is offline
post #15 of 15 (permalink) Old 12-30-2016, 06:38 AM Thread Starter
r-mm's Avatar
Thx. By idle I meant as you say, 2k
r-mm is offline
Replace with
