My GTV didn't include door keys, but finally sourced the correct key.
I locked passenger door, then unlocked, door won't open from outside via handle. However, lifting up on lever from inside will open the door. Any ideas?
If you remove the inner door panel you'll have pretty good access to the mechanism. There is a stop screw that might need to be adjusted. Also there are a couple of arms that are press fit to their joints - if they came off it wouldn't allow the outer handle to work.
Sorry, no pictures but it's pretty straightforward when you look at it.
Thanks for your response!. Discovered that the locking unit was the issue, I applied some grease to the spring loaded mechanism and it is working better but not 100% of the time. I can live with this.
Related Threads
Alfa Romeo Forums
2.1M posts
88.6K members
Since 2002
