03-16-2012, 05:15 PM
Bill, Just bought 205/60/15 H speed rated Sumitomo HRT A/S PO1 a directional tire that was tied for 1st in Consumer Reports tire test for UHP allseason tires. They are mounted on my new GTA 15x7 ET29mm Superleggera's.
101/105guy, Agreed different tire manufacturers have slioghtly different dia, width etc..
but most now are within .1'' of each other. In post #13 I refer to Michelin XAS as I think they were oe on GTV's at that time as well as a Pirelli and a Verdestien???
Brad Fischer, 1970 Euro-Canadian 1750 GTV Series 2, 105.44, Giallo Scuro AR112, AR1382413.
03-16-2012, 07:47 PM
Just trying to shed some light on real tire diameters vs calculated diam.
Some try to get as close to stock as possible.....
'64 Guilia Spider
'67 GTV
'68 Giulia Super
03-17-2012, 08:43 AM
For what it's worth I've got some Summis, HTR200's 205-50-14's on my 74 Spider and they are great in the dry but get very exciting in the wet. I also had them on my GTV but put them on the spider when I got 15's and am running Potenzas, 185-60-15 currently on the GTV. Great tire, they grip lightyears ahead of the summis in the wet, great in the dry and are within 2% diameter wise so my speedo is only 2-3 mph off at 60 which is within the margin of error of any 37 yearold speedometer. Originally I thought bigger is better but learned my lesson and went with 185's and the car is much more nimble and less strain on the steering box but I NEVER turn the wheel when not moving on either car.
currently
74 GTV restored daily driver
74 Spider restored
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
03-25-2012, 09:57 AM
FWIW, here's my philosophy for street tires, at least for wet/dry performance:
I rarely drive on the street - including some wonderful ridge line two-lanes - anywhere near the limits of dry tire performance. For my daily driver, I choose tires based totally on wet performance; I want the best chances in the infrequent worst conditions. Remember that roads with infrequent rains can be extremely slick as the faint oil build-up floats to the surface from the initial coatings of rain. It takes some substantial rain on frequently used roads to clear the slick off.
Secondarily, I look for durability - I won't choose a tire that will barely give me 10,000 miles!
But for my Alfa, I rarely drive it in the rain. Also, we rarely get unexpected rain around So Cal (heck, we rarely get the EXPECTED rain - it seems to go somewhere else). So for this car, I choose the best dry performance. Also, durability is of no account, as 10,000 miles will take a few years to accumulate! I'll drive as much tread off in autocross as I will in plain miles. So I pick the best street rated "A" class semi-racing tire.
The toughest choice for me is OE skinny tires or modern high performance tires. Fortunately, when I got my 14 by 6 Pannasports, I kept the OE steel rims. So I keep a set of Pirelli's in 185/70-14 ( the OE 14 inch tire from Alfa) handy. It's less than an hour to swap them. The difference from the hot 205/60-14 autocross tires is just amazing. The car is distinctly slower, but more nimble. It's quite an enjoyable day's driving. Parking is fingertip effort, rather than a Teamster exercise.
Right now I'm struggling with finding good "A" class tires in 14 inch. I may have to get a set of Alfaholics 15 by 6 (or 7?) GTA replicas.
Robert
03-25-2012, 10:56 AM
One other consideration that I surprisingly noticed when going from a larger diameter 175(/80)-14 to a "smaller/stock diameter" 185/70-14 on the '74 Spider was an improvement in braking force.
The car had lived in the city, and I preferred the addl. ground clearance of the bigger tires. Now it's in the country, and while I do need to be careful on one particular section of road with a dip that I used to pass over cleanly, I much prefer the bite of the brakes with the smaller tires.
Barely even an opinion - just a data point.
-Frank
SF, CA - '73 Berlina/SPICA (RIP), '65 Giulia Sprint GT, '74 Spider/SPICA, '93 164L
03-25-2012, 11:09 AM
That's such a small difference in rolling diameter (can't be much more than 0.4 inches?). More likely the difference you are feeling is due to the width of tire patch.
Robert
03-25-2012, 01:47 PM
Robert
good point.
-Frank
03-28-2012, 09:51 PM
Tire Size Calculator
Go to miata.net and check out their tire size calculator. It is the circumference that needs to match to not throw out the speedo calibration.
Regards,
Sid
74 GTV
07-16-2012, 02:41 PM
Originally Posted by fangio8c
I couldn't be happier with my Pirelli P4 in 185/70/14. Tirerack.com for about $60/ea. I like them much better than my previous set which was Yokohama Avid H4 in 195/65/14.
I need tires for my new to me GTV. It presently has very old Pirelli P500, 185 70 14.
The steering feels very nice, I just changed all suspension rubber ,tie rods,bushings etc...front and rear.
Now I would like to start doing some lapping sessions on the track. I was told 185 70 14 tires on the track is not a good profile !
What are the differences in steering, parking, harshness, road feel etc.. ,if any between a 185 70 14 vs 195 65 14 or 185 60 14 ?
Looking for a tire that I can use on a track and the street..if that's possible ?
07-16-2012, 09:42 PM
A mythical tire that doesn't exist, assuming you want to be competitive on the (dry) track and safe on the (wet) streets. Of course, you could always run street tires (all weather or summer) on the track if you're ok with not finishing 1st. Sometimes it's nice to have a warning (squeal) before the rear end snaps loose (especially if you haven't been racing for a while).
I like my Pirelli P4 185/70/14s for street. I love them compared to my previous Yoko Avid H4 195/65/14s. Nimble yet very confident handling, easier to park and a gentler overall ride (w/lowered suspension and Koni yellows). Many GTAs back in the day ran 13s (granted very wide 13s) not 14s or 15s. "Quicker turn in" was the claim.
BTW... don't forget to check your steering box before you go racing especially if you go with wide sticky tires.
Current:
1970 Euro-Canadian GTV 1750 S2
Previously Owned:
1967 US Giulia Super Conrad Stevenson built: 1750, transmission, and 4.10 lsd.
07-17-2012, 03:43 AM
Your best option is 2 sets of rims one for street and 1 for track.
07-17-2012, 06:48 AM
With tires on each...
Robert
07-17-2012, 12:50 PM
Tires like 185/70/14 on 14x5.5 or 6 for the street and 205/60/14 on 14x7 or 205/50/15 on15x7 for track use. You can better choose tread pattern, compound and manufacturer when the intended use is more single purpose.
07-19-2012, 10:54 AM
Thanks for sharing your experiences. The shop will be installing 185 70 14 Pirelli's today.
07-19-2012, 09:01 PM
Let me know what you think of the Pirellis. I'm looking to get a set in the coming weeks.
Regards,
Lawrence
_______________________
'71 Alfa GTV
'88 Porsche 911
'02 Audi S6
