Difficulty starting when hot
Its been a while since I posted, and I checked the posts but could not find one exactly fitting my description.
I have a 74 GTV Spica
Car could sit for 2 -3 weeks and when I go start it, crank it up to 2 times and fires up, runs strong no hesitation.
After I park it and about it 20 minutes later it is a bear to start crank and crank it finally starts.
Can't figure it out.
I did replace distributor with the one from centerline.
This problem did not exist prior to this.
Car runs noticeably better with the new distributor, starts stronger when engine is cold.
Any thoughts
Thank You
Tony
74 GTV Finally
79 Fiat Spider
