Can I adjust a 105 door lock to suit an existing key? - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 06-10-2010, 08:06 PM Thread Starter
alfa2go's Avatar
I have no idea when it comes to locks, keys etc., but if I wanted to get another door handle with a key lock with no key, is it possible to have that lock adjusted to suit a key that I have? Would any locksmith be capable of that job?
[B]Derek Entesano [/B]
1966 Giulia Super(Biancospino) 90% Restored
1967 GT Veloce(Rosso) Hibernating Project
1972 Montreal (Arancio) Restoration Project
[B]
[/B] (general classic Alfa Romeo website)
[B]
[/B] (blog on my Montreal restoration)
[B]
[/B] Lots of NOS 105 series parts for sale (always adding more)
alfa2go is offline
post #2 of 4 (permalink) Old 06-11-2010, 01:29 AM
billm105's Avatar
Hi Derek,
I had a locksmith do exactly what you're asking many years ago for my 1300TI. As far as I am aware a good locksmith should be able to make a key to fit a lock without keys or repin a lock to fit an existing key. Good luck.
Ciao for now,
Bill.
Bill M.
Director SNO Perth, Western Australia.
'66 giulia super
2007 147JTDM
billm105 is offline
post #3 of 4 (permalink) Old 06-11-2010, 03:30 AM
bshorey's Avatar
Send a message via AIM to bshorey Send a message via MSN to bshorey Send a message via Yahoo to bshorey
Yes you can. You need to remove the door handle, remove the tumbler mechanism, and inside you will find four or five tumblers, spring loaded. You can shuffle the positions of individual tumblers to fit the new key.
A couple of notes. First, it's easiest to remove the tumbler mechanism if you have the proper key installed. Otherwise, the springs will cause the tumblers to fly all over the place.
Second, you might find that you don't have the right combination of tumblers for the new key. In that case, you can actually leave some out and it will work fine (but the lock will be easier to pick, if you worry about such things).
Use the new key inserted into the tumbler mechanism to insert the mechanism back into the door lock.
HTH,
bs
bshorey is offline
post #4 of 4 (permalink) Old 06-11-2010, 05:19 AM
1966-2013
Tifosi's Avatar
Or, leave the offending tumblers and using a jewelers file, and with the key in the slot, file down the protruding part til it clears properly, in effect making a 'new' tumbler matched exactly to the given key.
Darren
as hosted by
Tifosi is offline
Replace with
