I continue cleaning out and up & below is some untouched and unmolested pieces as removed in the late 60`s & early 70`s and put by. Just a quick list with some #s. If you need info or want something my email is above. No junk, all stored dry. For you "restorer" types. My hoarding is over....
Don`t post questions here. Use my email.
Alfar7@aol.com
Don`t seek gifts. Threre is none, prices are barely fair as I know what they are worth and they will be worth no less later. But I would like a lot of this stuff elsewhere, and my wife has locked up the 2nd floor of her garage.
Solex 35 APAIG/0 439358 complete with all linkage (both bell cranks) on manifold # 1315 44065 never been off manifold.
Solex 32 PAIA5 73338 (with assembly tag 10112) on man. with no # Complete and has never been off of manifold
2nd carb as above 32 PAIA5 857840
Manifold for Solex complete with water outlets, thermostat & t-outlet. # 10560 1600 02
(large carb bores & ports)
Know anyone with something using Weber tipo 28 ICP3s?
I have a matched set # 78013 & 54976
Thick engine/transmission spacer from 750 series application
Some old Lucas & Marelli distributors but I won`t list.
I have a few 101 front covers. one with water pump, one with Oil pump and pickup (alum. have 2 pickups) for 101 20 aluminum oil pans (have 2, #101 20 0120000 Z, both in beautiful shape. No broken fins both almost perfect. One has oil temp sender.)
Some perfect cam covers, 50`s-60`s no vent, no dips, early type. Two without the 6 hold down clamping nuts, One with small alum socket head cap screw type that are held in with retaining clips under. All there in good condition.
Best for last. (will only go as package)
Excellent (full thickness 4.350) head from Very early 101 06 1300 Veloce (`59-60). Head has very small casting plugs in top of head, and oil galleries are drilled as in 750s and covered by steel plates retained by two 6mm studs. Complete with valves, Cam cover has early flat 750F type socket head hold down nuts with retaining clips. Never drilled for any air cleaner system support. Gaskets under hold down nuts are still good!
Veloce intake manifold has no corrosion! (no rust on the steel heater outlet (still shiny plating) or white corrosion on the water outlet at hose, has temp sender . No #s on manifold. Carbs are original 40DCOE2s #s 528 & 542 still connected with original yellow metal flex tube. They will require rebuild or at minimum freeing up the pumps which I may do. Or not.
Please don`t ask questions here. Use my email. Not PMs My Email!
Alfar7@aol.com
Richard
