I have just rebuilt my Solex to source the vapor lock I have been constantly experiencing the past two years. Two possible causes:
1. Center emulsion tube was loose and easily removed. What glue should I use. Is Permatex gasket cement gas-resistant ?
2. The four bolts locking in the thick heat gasket and lower portion were slightly loose.
3. Possibly running rich because float not set at right level. What is the proper hex cut off valve (in the float bowl lid) to use for street use. I have three all different sizes.
4. In the rear above the round weight is a piston in a round oil cylinder. This should raise up when the lower butterfly valve is activated. The throttle control rod which opens the secondary has no effect on this weight when opened to full throttle. It just sits there and the lower butterfly does not open. What am I missing or did I reassemble something wrong? ? Should there be a spring attached between the weight and the outward facing lever attached to the left body throttle ?
Further note: the electric fuel pump works great, the thick heat gasket is fine and the hole below the intake manifold is open, but the car still gets vapor lock after engine is heated up following a strong run. Am I missing something else?
Graham Arlen
Oakland CA
Alfisto@aol.com
Graham Arlen
