Old 12-13-2004, 12:02 AM
giuliaguy giuliaguy is offline
Is This A Veloce Plenum?
Is this a Veloce plenum? If not, what year and model Alfa is it from? It's mounted on a 1750cc Berlina engine, but in my '65 Spider Veloce.
Spider Veloce Plenum?
GiuliaGuy
Old 12-13-2004, 06:23 AM
AlfistiSA's Avatar
AlfistiSA AlfistiSA is offline
Yes, it's the same part as fitted to the 105 Giulia Sprint GT / GT Veloce / 1300 GT Juniors & very early 1750 GTV Mk1's.
The top is a later part, and not for a '65 Veloce or early Sprint GT - it was probably fitted to a GT Junior or a Mk 1 1750 GTV. The early tops did not have the breather pipes fitted as the motor vented to atmosphere at the back of the block. Consequently the cam cover does not have the vent, in addition, neither the cam cover nor the head would have had those 2 lugs at the front, they were added in '66.
Other than that the dimensions are identical.
Cheers
Greig
Sunny South Africa
Some 750's
Some 101's
Some 105's
Some others
