I spoke to someone who has one & this slightly slanted piece appears to be correct. The correct engine should have a 2 piece sump, the instruments read higher, the engine mountings are different, the Tipo plate is different, the inlet manifold & air plenum are different, the cams are different, the car should run an electric fuel pump instead of the mechanical pump.
Hope this helps
Regards
Greig
