04-15-2008, 06:33 PM
Valve clearance
Just curious what those of you with 1300 Veloce engines set your valve clearance to. I have mine set to the workshop manual standards of .045 mm intake and .5 mm exhaust (about 19 and 21 K) and they make a hell of a racket, especially cold. Seem much better when warm but it takes forever and 15 miles to warm up. I have a friend who races a Giulietta and he says he sets them to about 12 K. Any thoughts on this?
George
George Kraus :: Portland, OR, USA :: 1960 Giulietta Spider Veloce :: Complete restoration :: http://tinyurl.com/yq4evt[/url]
04-15-2008, 08:07 PM
George,
Running .017" intake and .019" exhaust will quiet things down considerably, while still giving you a safe margin provided you check the clearances occasionally.
04-15-2008, 08:28 PM
Richard Jemison
Vc
By reducing clearance you increase duration and the downside is the additional overlap kills off low & mid torque. But if you drive it in the higher rev range who cares....
Richard Jemison
RJR Racing
http://scuderiagiallo.com
04-15-2008, 08:45 PM
Valve gear noise
Hi George,
As Alfar7 might agree, part of the noise is the design of the ramps themselves. It would be interesting to see what the clearance is hot, when they quiet down. It might be possible to just tighten them a little without getting to the point where you lose the low and mid range torque. I have never checked this myself, so I don't know if there even is a compromise setting.
As he is the "Cammaster"  , Alfar7 can suggest a grind that will give you both, better low end torque and high end Hp with a modern design. I have a set suggested by Richard, that I will be using in a restored Ausca single plug 1600.
The design he has suggested uses a much more modern ramp profile, and should offer both long valve train life and improved performance.
 Gordon Raymond
Illinois SNO Chapter DIRECTOR
04-16-2008, 06:54 AM
with the Librarian
Generally, the clearances will tighten up about .002-.003 thousandths.
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
04-16-2008, 07:44 AM
So, Jim, tightening them by .0025 would probably only slightly reduce George's clatter and, in all likely hood, not affect performance in any noticeable way? Probably not worth the trouble.
With older cam profiles and Alfa grinds, my only experience with these minute adjustments was to get cam timing dead on, cold, with different clearances from one valve to another. As I learned from Richard J. this was a waste of effort, as the timing varied from Alfa's inability to cut each lobe of each cam exactly the same to begin with. I was very impressed with the computer readouts from WebCam on OEM Alfa race cams. With modern technology, the exact variations became apparent. Further, WebCams reprofile was precise, by comparison. This was very educational for me.
 Gordon Raymond
04-16-2008, 01:44 PM
Thanks Joe, Richard, and Gordon.
I should have stated I have the Centerline 1400 kit and the head had been worked by Sperry Valve Works in 1985. The car had sat stored since '89 until 2006 when I got it. On the Sperry receipt it says: Valve job with port and polish; install 80.5 seats and valves; R & R exhaust studs; adjust valves; straighten cams; line bore cams. When I rebuilt the engine I had new guides, seals, and springs added and had new seats installed/cut and we trimmed the valve stems to keep the same overall length. I was going to add new valves but standard 1300 valves were too small, so I ordered 1600 valves thinking that was what Sperry used, and they were too large. So, we cleaned up the existing valves and used them. The machine shop that did the work thinks the valves might have been Alfa V-6 valves? The cams had the correct part #'s for a Veloce but did not look stock (modified). There is obvious port and polish work showing on the intake. So, is it still worth the trouble to change clearance?
My friend Denny Pillar also mentioned that if I used a straight 40 w oil it might quiet things down. Maybe the noise I am hearing is perfectly normal. it's just that I don't know what normal is supposed to sound like. it reminds me of the first time I took a Triumph 650 motorcycle out on the freeway I thought this thing is coming apart and I keep trying to shift into another gear. Now I know it is normal and think nothing of it.
Cheers,
George
Anyway, this is a little more info to fill in the blanks.
04-16-2008, 05:28 PM
Hi George,
I'll send you a PM with my E-Mail address, send me yours and I will send you a 15 second video with normal GTA valve noise.
 Gordon Raymond
04-16-2008, 05:43 PM
Per Gordon's recomendation, I tightened up the clearance on my Duetto's 1600 cams :
10548 intakes are at .016 and 105020320001 exh. cam at .018.
Wonderful results! Quiet when cold and very good torque from low revs.
Thanks !
'65 Guilia Spider
'67 GTV
'67 Duetto-in progress
'68 Giulia Super
'70 Giulia 1600 'S'
04-16-2008, 05:56 PM
Valve gear noise
Whew  ! I'm glad it works  ! I just sent George a video of my GTA engine running. It does make a noise! Just remember, generally, not always, valve clearances close with use. The tighter they are set, the more often you should check, particularly any that seem like they like to tighten up  .
Moreover, as Richard has pointed out, the actual valve timing will change. Heed Richard's advice in all cam related matters. He is very knowledgeable, and I find his experience and wisdom invaluable  .
 Gordon Raymond
04-16-2008, 06:44 PM
I have already noticed they are quieter now that I have as little as 220 miles on the engine. I think I will just keep things as they are right now and let everything seat in.
G
