Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > Giulietta & Giulia (1954-65)
Old 04-05-2008, 08:10 PM
johnnym's Avatar
johnnym johnnym is offline
750 Sprint Body part numbers
I wonder if someone could help. I have been in communication with AFRA to try to buy replacement body panels for my 57 Sprint. I have been given a quote for various panels, but despite having an Italian friend translate, I am not convinced the panels are the right ones (the descriptions seem wrong).
Does anyone know the part numbers for the following?
-Sills (rockers)
-Rear valence, including corners
-floors
John
1957 750 Sprint (we can rebuild her!)
1986 Spider + 1999 146 Ti
Old 04-06-2008, 03:44 AM
bjogi bjogi is offline
I would recommend you to by the Alfa Giulietta CarDisc CD, available from Highwood Motors. It is invaluable when you are working with the car!
Old 04-06-2008, 04:44 AM
yvesmontreal yvesmontreal is offline
What is your car's serial number? A 1957 should be an early type body with small headlights (< 7") and column shift.
I have a 750 parts catalog and can look up the numbers, but these bodies were practically hand made... it is doubtful AFRA has anything in stock for these.
Old 04-06-2008, 07:21 AM
johnnym's Avatar
It is indeed a small headlamp car. This is at the root of my concerns over the parts I have been quoted by AFRA- I think they are giving me a list of what they have, rather than the parts i have asked for.
John
Old 04-06-2008, 07:47 AM
alfa soon's Avatar
alfa soon alfa soon is offline
biondilmierati.com ::
This guy seems to get good reviews when ever his stuff comes up and I bet if he doesn't currently have what you need could either find or make it for you.
I haven't seen an update for your car in a while, sounds like you are back on it.
Matt
61 SS59 Sprint72 Fiat 124 Sport Sedan58 Sprint Veloce72 Berlina
Old 04-06-2008, 03:51 PM
johnnym's Avatar
If AFRA have it, I will buy from them as I have a friend about 10 miles away who can pick up. I have the biondi website, and will get in touch, but he is expensive.
Not quite back on- it is in the UK, and I am not! However, I have a long period of time off in the summer, and am preparing the ground by buying many of the parts I know I need.
Old 04-06-2008, 06:08 PM
Here are the part numbers you need from my 11-1957 parts book:
Sills, outer: LH 1493.26709, RH 1493.26712 "fianchetto pedana porta"
Sills, inner: LH 1488.10041, RH 1488.10042 "lungherone interno"
Rear valence: 1493.26706 "parte centrale posteriore"
Floors: 1493.10711 "pavimento"
Now, as far as I can see in the book, the valence corners are part of the quarter panels. This is a different construction from the 101 and the interim 750 Sprints I've owned, on which the trunk floor protrudes outside, the bottom of the fenders and top of the valence being spot welded onto it, forming a lip hidden by the bumper.
The floor is something else. This part number is for a single piece, from behind the firewall to the tail of the car! It is unlikely that this panel was ever used by anybody as a replacement...
My guess is that the floor stamping was supplied by Alfa to Bertone (or Pininfarina, or Zagato) and consequently was not changed when the 101 body was introduced. So any 101 replacement floor panels could be used.
If you have access to a talented panel beater, any reasonably affordable panel can be adapted and will be easier than starting from a flat piece of sheetmetal.
When I was trying to restore the 101 Sprint, I had a panel beater redo the sills, door bottoms and generic rust left and right. One key area was just below the headlamps: on both sides there are mouths for fresh air intake, which are rust traps. To get everything welded I paid 400 hours of work. I eventually bailed out of the project.
When I bought the car, two brand new panels were included: the two corner valences. Obviously hand made, these two panels had part numbers hand written on them by a milanese craftsman over 40 years ago.
You may also want to look at this Canadian source of panels:
Alfa Romeo 750 101 Roadster Body Panels
No Sprint parts are listed, but they were working on an interim 750 Sprint years ago and I sure they would adapt parts to your needs. Contact the owner, Allen Hall, for more info.
Old 04-07-2008, 10:46 AM
johnnym's Avatar
Brilliant reply! Many thanks Yves..
