04-05-2008, 08:48 AM
Convertible top Question
Greetings,
I am a long time car nut, just got my first Giulietta Spider, it's a '62.
The car has been idle for a few years, and I am having trouble lowering the top. I have loosened the header latches  , but it does not seem to want to go very far back, or down. Is there a trick, or do the pivots just need more penetrant?
Also will need a new top, any recommendation for a supplier, I am in N Cal.
Thanks for entertaining my embarrassing newbie question
Alan
04-05-2008, 01:05 PM
Got it
Got it, still open to recommendations on a source for a top.
Alan
04-05-2008, 03:44 PM
Director BC Chapter SNO
You found the latch things--that's a plus.
I bought mine in November, 2006 and although I had had one decades ago I could not recall the latches  . Had to go through the driver's instruction book.
And then Eureka!
Welcome to the BB
1962 Giulietta Spider: Graphite Grey/red; "Tuned" 2L.
1993 Subaru Legacy Turbo Wagon(200 whp).
04-06-2008, 06:53 AM
Alan
Welcome to the AlfaBB!
So you have a 62 Giulietta Spider; have you confirmed that it's a 62 by contacting Archivio Storico? If not, ask for the build date: SERVICES@ALFAROMEOAS.IT
This is important as yours could be a transition car with a mix of parts from different series.
There were at least three variations of Spider top frames used on 750/101 Spiders so you want to determine exactly what you have before purchasing a new soft-top.
Pictures are always appreciated on the AlfaBB.
While there are many suppliers of new soft-tops, all will require some fitting and fooling with to result in a proper funtioning top. Use the SEARCH feature to find previous threads.
Alfista Sapien
04-06-2008, 12:13 PM
Originally Posted by GTD
Alan
So aside from 750 tops, what were the differences made to the 1o1 series tops. I have seen some 101 series that were bolted directly to the back deck. I have a 1960 Giulietta that I am about to order a Robbins top for. What style should I order? Please see the photo of my frame.
Cheers,
George
George Kraus :: Portland, OR, USA :: 1960 Giulietta Spider Veloce :: Complete restoration :: http://tinyurl.com/yq4evt[/url]
04-06-2008, 08:17 PM
Cheers,
George
I think that there is only two things that you need to consider when ordering a top. At least this applies when ordering a top from world upholstery. First is whether you have a long or short wheelbase car. I think that you have a long wheelbase car, so that issue is known. The next item is how the top meets up with the back bow. From what I know, there is the type where the straps are sewn into a metal loop (which is what my car has). There there is a type where the straps are riveted to the back bow. I think this is more common for the later or 101 cars.
If in doubt, take a look at world upholstry's website. If still in doubt, just give them a call. It is their livelyhood to know what you need, and so they would be able to help you sort out the details.
Cheers,
Jon
04-08-2008, 08:11 AM
Alan
There were at least three variations of Spider top with to result in a proper funtioning top. Use the SEARCH feature to find previous threads.
Leave it to a guy with 1300 posts to say "search the archives"
Thank you guys for all the replies. I know zip about this car, except that it is a great driver. I know there are many permutations, and running changes, I was so excited about the car, I didn't want to log any time on the computer.
This Alfa was part of a 3 car package with a Fiat 500 and Bristol 401!! So I have my hands full. When I catch up, I will search this great forum and figure out exactly what I have.
Thanks again, Alan
06-16-2008, 08:54 AM
Instructions and/or tips on replacing a 101 convertible top?
I have replaced a couple of tops on the later 105/115 spiders, but I had the advantage of having the factory manual. Are there any step-by-step instructions on replacing a giulietta top? Unfortunately, all I got with my project was the frame with the top already removed and tossed. I have the frame re-installed after getting it powder and fitting pretty well with new wood on the header. Now I'm stuck. Any suggestions out there?
comancheflyer
61' Giulietta Spider
90' Graduate Spider
83' 911SC Coupe
60' PA24-180
