Old 04-01-2008, 03:20 AM
bjogi bjogi is offline
Safety belts in a Giulietta Sprint
Does anyone know how to install safety belts in a Giulietta 750B? No harness but but lap-diagonal belts.
bjogi
Old 04-02-2008, 09:18 AM
ecdysiast ecdysiast is offline
Seat belts
I don't have the exact web reference with me (send me a note if you can't find it yourself and you're in a hurry) there's at least one manufacturer of belts for specialty (i.e., old) cars that has a diagram of installation. Look for Seat Belts Alfa Sprint or Giulietta Sprint or some such. The top mounting point can be either on the top of the rear wheel intrusion, or on the inside of the rear window frame; the other point is on the floor back of each seat's inner track.
Jeffrey
63 Sprint
65 Spider
Old 04-03-2008, 07:11 PM
Andrew Andrew is offline
Lap belts will normally be mounted on the floor, behind the seats, with good strong hardware and large-area washers on the underside to spread the load out. Inner belts could probably go on the sides of the driveshaft tunnel if they don't interfere with the shaft or anything running along the underside of the tunnel.
Andrew
