Old 03-09-2008, 01:49 PM
1750s's Avatar
1750s 1750s is offline
Brake Light Switch Sticking
My 62 Sprint brake lights remain on once applied and after brakes released. I'd like direction on likely cause and where to locate the problem - at the brake master cylinder or the switch located below the reservoir.
Old 03-10-2008, 11:47 AM
Peter's Avatar
Peter Peter is offline
if it's the same principle that is used on 105's, it's a pressure actuated switch. So if you release the brake pedal, do your brakes release normally? If that is the case, I would suspect the switch. They are relatively inexpensive and easy to replace (on a 105, not sure about your Sprint)
Peter
Currently:
'69 Euro 1750 GTV
Previously:
Old 03-10-2008, 11:56 AM
rcess's Avatar
rcess rcess is offline
I agree it is probably the switch. Replacement is a bit harder than for a 105, since the heat shield must be removed.
Bob Cess
'59 Giulietta Sprint
'60 Giulietta Berlina
'62 Giulietta Spider
'69 Spider Veloce
