100LL Aviation Fuel Anyone Running it in Their Alfa - Alfa Romeo Bulletin Board & Forums
post #1 of 26 (permalink) Old 04-21-2017, 11:48 AM Thread Starter
vespaholic_com's Avatar
I'm going to run it in my 1970 Mustang Boss 302.
100 Octane
Has Lead
No Ethanol
Less than $5 per gallon at a local airport.
The Boss community folks say it works and they speak highly of it.
What do you guys think about it for a Veloce spec Giulietta 1300??
1959 Alfa Giulietta Spider / 1970 BOSS 302 / 1967 Ford Galaxie 500 Conv. / 1999 BMW Z3 / 1963 Jeep CJ5
vespaholic_com is offline
post #2 of 26 (permalink) Old 04-21-2017, 12:05 PM
Push hard and live
DPeterson3's Avatar
A few points about aviation fuel.
It has a LOT of lead in it. The "LL" indication is in reference to the fuel it replaced, which was 100/130 octane. 100LL still has roughly 4 times the lead of aviation fuel 87 octane, which is increasingly hard to find.
To obtain the 100 octane rating with reduced lead levels, there are a lot of interesting chemicals that had to be added. My Mooney gas tank, which is created by spreading sealant around inside the wing, would last a long time between leaks with the original 100/130. With 100LL the sealant begins to break down and need repairing or a complete replacement typically about every 7 - 10 years. I'm not sure what all the chemicals are, but they may be worse than ethanol.
Aviation fuel has a lower vapor pressure than car gas. Among other things, this is to reduce vapor lock when flying at higher altitudes. It also makes aviation fuel harder to start than car gas.
It has a blue dye in it that WILL stain paint surfaces. If you act reasonably quickly, you can clean it off with rubbing alcohol, but even then the blue dye will eventually stain whatever it gets splashed onto.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is offline
post #3 of 26 (permalink) Old 04-21-2017, 12:07 PM
PhilBoncer's Avatar
No ethanol is good for your vehicle.
Lead is bad for you and other living creatures.
100 octane may cause carbon buildup if used frequently.
PhilB
PhilBoncer is offline
post #4 of 26 (permalink) Old 04-21-2017, 12:09 PM
Richard Jemison
Alfar7's Avatar
Aviation gas
I use it mixed 50/50 with ethanol free 91 octane pump gas in the "Montreal Coupe"
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #5 of 26 (permalink) Old 04-21-2017, 12:13 PM Thread Starter
I wish I could get ethanol-free pump gas around here!
I'd just go ahead and use that.
post #6 of 26 (permalink) Old 04-21-2017, 12:17 PM
Andrew's Avatar
I used it 1979-1981 when I worked at an FBO in San Diego County. We could take avgas that was drained out of planes' tanks, couldn't be put back in.
I never could tell any difference, other than that it was free.
Andrew
Andrew is offline
post #7 of 26 (permalink) Old 04-21-2017, 12:18 PM
jburning17's Avatar
You might be able to. Check here for a listing near you.
Ethanol-free gas stations in PA
current: '57 spider normale
previous: '74 spider in that weird yellow color
I spend too much money on my car. It's Gordon's fault.
jburning17 is offline
post #8 of 26 (permalink) Old 04-21-2017, 12:22 PM Thread Starter
@jburning17: I did check that link earlier.
It's only $75 +/- for 5 Gallons.
F-that!
It's only sold in 5-Gallon cans.
post #9 of 26 (permalink) Old 04-21-2017, 12:28 PM
jburning17's Avatar
F-that!
Woof! That's absurd!
I guess that I am lucky this time. There is a place about a mile away that has it for reasonable.
post #10 of 26 (permalink) Old 04-21-2017, 03:01 PM
divotandtralee's Avatar
I'm no chemist but I've run Avgas at times and it is fine. It won't harm your engine. It won't destroy anything. It's more octane than you need but running Super pump gas in a Chevy Tahoe is not money well spent either and doesn't harm it.. Legally airports cannot sell gas for road vehicles as they are supposed to keep a log on where it goes.. like aircraft.....not that it matters. It's their problem not yours if you get a tank full. I think the only advantage to it is shelf life. It won't turn to sugar and water in storage like 10% ethanol. 50-50 won't eradicate that problem just turn the gas to 5%. My advice is keep the ethanol fresh with 1/3 to 1/2 a tank on tap. Fill-ups put you in that zone where the gas can go bad if it is driven so occasionally. U.
divotandtralee is offline
post #11 of 26 (permalink) Old 04-21-2017, 03:35 PM
Gubi's Avatar
Oh for the love of...no. Just no.
1991 Spider
Gubi is offline
post #12 of 26 (permalink) Old 04-21-2017, 03:42 PM
so finish your point.. I'm all ears
post #13 of 26 (permalink) Old 04-21-2017, 03:57 PM
Gubi's Avatar
Well unless you've found a species of yeast that can live in 90% gasoline and that can run a reverse fermentation process to take energy and CO2 form the environment and use them to convert ethanol back into sugar, I'm going to say you're wrong on that whole sugar thing.
Beyond that I'm not contributing to another octane thread.
1991 Spider
Gubi is offline
post #14 of 26 (permalink) Old 04-21-2017, 04:27 PM
xalfaracer's Avatar
I ran 'green' av gas in my 1300 Veloce SCCA racer for years until purpose designed racing fuel became available. It was hard to get but it worked well. Of course, that was a lot of years ago.
xalfaracer is offline
post #15 of 26 (permalink) Old 04-21-2017, 04:36 PM
Beware the Tax Man
f4driver is offline
Replace with
