How to remove bolt from chassis-attached clutch mechanism - Page 2 - Alfa Romeo Bulletin Board & Forums
post #16 of 27 (permalink) Old 03-16-2017, 11:35 AM Thread Starter
clescn's Avatar
Hi Gordon: Thanks.
Nick
clescn is offline
post #17 of 27 (permalink) Old 03-16-2017, 11:36 AM Thread Starter
clescn's Avatar
Good ideas, all. We won't give up on this....
Nick
clescn is offline
post #18 of 27 (permalink) Old 03-16-2017, 11:37 AM
clutch pivot bolt
Just adding to Alphill's suggestion of drilling a hole for a future grease nipple just drill through the steel tube as well until you contact the bolt, put lots of penetrating oil in, but then drive a dowel pin in so that it engages with the steel tube. Now you can apply some serious torque to the bolt which should be more effctive.
The bolt will be seized in the tube because the tube is running in bronze bushes and there will possibly still be grease in there not the tube in pivot.
danjamds is offline
post #19 of 27 (permalink) Old 03-16-2017, 11:40 AM Thread Starter
clescn's Avatar
Thanks from across the big pond!
Nick
clescn is offline
post #20 of 27 (permalink) Old 03-16-2017, 11:52 AM
Gordon Raymond's Avatar
These rust solid from moisture and lack of use. If it is restored to similar to new, without serious modification, and lubricated with a modern synthetic or semi synthetic, waterproof non hardening grease, it should remain free about forever without need of relubrication.
Gordon Raymond
Now:
Gordon Raymond is offline
post #21 of 27 (permalink) Old 03-16-2017, 12:16 PM
divotandtralee's Avatar
Agreed.. the footnote.. If the bolt is frozen, I can just about guarantee the sleeve is too and even tighter regardless of the bronze bushings..don't ask me how I know.
divotandtralee is offline
post #22 of 27 (permalink) Old 03-16-2017, 12:27 PM
pivot
I do have an extra pivot and steel sleeve if needed. And a bolt that is too long but can make it the correct length.
hotlegs32 is offline
post #23 of 27 (permalink) Old 03-16-2017, 12:35 PM Thread Starter
clescn's Avatar
Thanks...I'll certainly keep this in mind!
clescn is offline
post #24 of 27 (permalink) Old 03-16-2017, 12:51 PM
GTD
GTD's Avatar
Nick
Stop drinking the Kool-aid and return to reality - sacrifice the rusty bolt!
Drive to Harbor Freight in Albany or Amsterdam and buy their cheap pneumatic high speed saw and some thin blades or use a Sawzall and thin blades.
Spread the bracket ears slightly and use a saw blade to cut the bolt between the ears and the tube.
The LOBO bolt is seriously rusted .. you will be replacing it anyway.
Alfa Sapiens
GTD is offline
post #25 of 27 (permalink) Old 03-16-2017, 01:41 PM
That's what I would do. However I would be careful NOT to damage the bell-crank these days! Karen may have what you need now, but they will be HARD to find otherwise!!!
Gordon Raymond
Now:
post #26 of 27 (permalink) Old 03-16-2017, 01:51 PM
Bolton Landing NY... you have snow up to your arm pits. This car isn't going anywhere soon.
post #27 of 27 (permalink) Old 03-16-2017, 01:53 PM
Can't go anywhere anyway. Clutch pivot arm already saw too much snow or moisture! Fix it!
Gordon Raymond
Now:
