Oil & Water temp senders - Alfa Romeo Bulletin Board & Forums
post #1 of 11 (permalink) Old 03-13-2017, 11:24 AM Thread Starter
Raimondo's Avatar
I'm shopping for some Oil & Water temp senders, but have seen more that one type regarding the fittings; spade type, et al.
Which is correct for a '64 Giulia Spider?
Ray
Oklahoma SNO Alfa Chapter Director
'64/66 Giulia Spider finally back in the garage and painted
'75 Olandase Blu Alfetta Sedan 2.0 & '88 Red Milano Verde; both long gone and dearly missed
Raimondo is online now
post #2 of 11 (permalink) Old 03-13-2017, 01:09 PM
Alfajay's Avatar
You're the Oklahoma SNO Alfa Chapter Director, for pete's sake! What do you care about correctness?
Kidding aside, my '64 Giulia Spider has bullet connectors on the oil and water temp sensors. Female on the sensor, male on the wire.
'63 Guilia spider
Alfajay is offline
post #3 of 11 (permalink) Old 03-17-2017, 12:38 PM
Andrew's Avatar
I would have expected spade fittings on a 64, since it has Bosch electrics, right? Are the other fittings on the car bullet type, Jay? Taillights and whatnot?
I have a couple senders lying around, mixture of spade, bullet, screw type. Far as I've read, oil and water senders are the same item.
Andrew
Andrew is online now
post #4 of 11 (permalink) Old 03-17-2017, 01:26 PM
Gordon Raymond's Avatar
My '65 Spider Veloce is all spade type with a "U" type on the oil temperature sending unit wire.
Gordon Raymond
Now:
Gordon Raymond is offline
post #5 of 11 (permalink) Old 03-18-2017, 02:10 AM
senders
I've just bought two senders from Classic Alfa for my '62 Sprint which have spade connections (they are the same for water/oil). My original oil sender was a bullet type so I've changed the wire connector to spade. Strangely my original water sender was spade and looks like it has never been tampered with.
The main problem is that the new senders have the cone seat sealing which is OK for the oil sender but not for the water version because the manifold has a tapped through hole with no seat. They also have 17 mm hex whereas the original water version had a 21 mm hex so that a copper washer could be used. I've managed to fit the water one and get it to seal by making a v.thin aluminium washer to wind it along the thread + some sealant. Probably dont need the washer, just sealant.
Gauges still don't work though although they will give full scale deflection if the wires are shorted!
Never ending problems.
danjamds is offline
post #6 of 11 (permalink) Old 03-18-2017, 06:27 AM
Alfajay's Avatar
Andrew:
Oops, my Giulia is probably a '63, not a '64. VIN is 375165. It's an early 1600 normale with drum brakes. All the electricals are Bosch, and most of the connectors are bullet including the taillights.
'63 Guilia spider
Alfajay is offline
post #7 of 11 (permalink) Old 03-18-2017, 07:51 AM Thread Starter
Raimondo's Avatar
I have no idea about other electrical connectors as my wiring loom is out for refurbishing and all lights/connectors are boxed away.
Danjamds, did you happen to take any photos of the modifications you had to make?
I have an early 105 screw-in thermo intake; would that affect the need to use a different washer as you did?
Ray
post #8 of 11 (permalink) Old 03-18-2017, 08:08 AM
The water SENDING unit with tapered seat can be modified easily with a lathe cut. With these on stock manifolds, Alfa used a copper sealing washer. I imagine you could easily cut a taper into the manifold, but that doesn't strike me as quite right. I seal them all in place with a bit of Permetex Ultra Grey anyway, and none ever leak.
Gordon Raymond
Now:
post #9 of 11 (permalink) Old 03-18-2017, 08:15 AM
carl750's Avatar
Sener variations
Maybe the attached will help explain the variations:
File Type: pdf Alfa 750-101 Gauges Senders for AlfaBB.pdf (479.3 KB, 23 views)
carl750 is offline
post #10 of 11 (permalink) Old 03-18-2017, 08:26 AM
Push hard and live
DPeterson3's Avatar
I have found that VDO offers a wide array of senders. Most can be had via Summit Racing. However, the full VDO catalog can be a little hard to locate, as most of the listings you find are for more modern cars. Try digging up via the German VDO website. You can eventually find super-detailed descriptions for thread, sealing method, temp/resistance span, etc.
Once you've figured it out, the part can be ordered. Probably have to give up the bullet, though.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is offline
post #11 of 11 (permalink) Old 03-18-2017, 09:26 AM
senders
Pics of my original(?) senders below. The spade version is the water sender. The threads are the same, M16.
My car is all Bosch except for wipers.
Didn't take a photo of my ally washer but I just cut it from 0.5 mm sheet. On reflection I think any good sealant will be fine without the washer.
I've attached a pic of the sender sold by Classic Alfa.
danjamds is offline
