#46 (permalink)
Old 04-10-2008, 04:07 PM
Director BC Chapter SNO
Lightbulb
Elsa Lanchester in "The Bride of Frankenstein" , 1935 movie.
Bob
  #47 (permalink)
Old 04-12-2008, 02:30 PM
Gordon Raymond's Avatar
Thumbs up Measurements requested
Hello Einar,
Though you hopefully have my E-mails by now, these pictures and measurements belong on the BB for others to use! My friend, Terry Rushbrook was kind enough to take a 20 mile drive out to his restoration shop and take photos and measurements, so I will submit them here with notes.
The hood to grill mounting on the nose is 11.5 CM
The top of the fender to the arch is 17 CM
The wheel opening to door edge is 19.5 CM.
The wheel opening itself is 70.5 CM
Terry took a bunch of pictures I will attempt to post here and in the following post. THANKS!!! Terry
Gordon Raymond
  #48 (permalink)
Old 04-12-2008, 02:36 PM
Thumbs up Measurements requested part II
More. GR
  #49 (permalink)
Old 04-12-2008, 03:58 PM
Thank you Terry and Gordon!
And you're right, they do belong here. I'm sure I will not be the last one to benefit from them.
The first picture also shows the relations better than any I've seen. The Headlight openings seems to be on line with the front of the hood opening. Since I have to make new the first 10cm of the fenders, that is a good reference to check. I don't feel I can rely on the remains of the front placing the headlights right. Now I have a check on that. It also shows the slant of the grille better than any picture I already have, and I have a lot by now.
Here's how I left it half an hour ago:
The nose is now off and I'm almost done grinding the edges clean. Here it's just stuck onto the bumper bracket tubes. When everything is cleaned up there will be around 7-10cm missing between the front piece and the body. And as mentioned the headlight openings also needs to be made. The missing steel is partly because it was not shaped, just bent. And partly because the position and angle of the front was wrong.
Then I will establish the 11.5cm by putting in a strip of steel along the top of the "nose". This strip will flex enough to establish the rake of the grille. Terry's first picture will be my primary guidance. Another measure I've seen in other pictures is the distance from top of the bumper support tubes up to the grille opening. It's just a bit more than the diameter of the tubes. And the angle seems to be right when a vertical beam is touched to the grille opening and the touch point is in the same height as the top of the "eyebrow".
This placement of the front will be temporary while I make the necessary parts, which will take some time. In the mean time I will hopefully have had access to an unmolested Spider to check several measurements to get it right before welding in the parts.
One of the reasons for these rantings is that if someone see something wrong in what I wrote, then hopefully I will be corrected here.
Einar (AT) eunet (dot) no.
1996 960 3.0 24V
1988 780 Bertone
1986 Maserati Spyder.
1995 Alfa GTV 2,0TS (4 sale)
1962 Alfa Giulia Spider
  #50 (permalink)
Old 04-12-2008, 07:24 PM
Lightbulb Idea
Einar,
I have another idea, I will try to photograph tomorrow. It is not a problem to remove the grill on my car in my shop. Then I will put a large RT angle square on the floor, center it in the grill opening, and measure the offset from perpendicular from the shop floor. These measurements should give you an exact angle.
More tomorrow. Gordon Raymond
  #51 (permalink)
Old 04-13-2008, 02:23 AM
It would be very nice if you would do that Raymond. Getting access to the lower bolt on mine was not easy. Or rather the fact I had to at the same time hold a scewdriver on the outside. But maybe the original grille have a fixed bolt? If that's the case, give it a nice dose of copper grease when having it out. The low location and mix of different metals promotes corrosion.
If you do this, then also bring a carpenters level and measure the angle of the chrome trim below the door. This angle can change quit a bit, especially on such a light car.
1996 960 3.0 24V
1988 780 Bertone
  #52 (permalink)
Old 04-13-2008, 03:15 PM
Grill measurements for nose angle.
Einar, Here we go! Here's some pictures that will help. First is my set up with the square, centered on the grill mounting holes. Then a couple of pictures of the measuring set up. Though it does not show clearly in the photo, when the square touched the top hole, the bottom edge of the lip for the grill was 33 mm away from the square.
Next the seam of the sill or rocker panel on which the trim is centered is level using a carpenters level. It is a straight line from the front fender, under the door to the back. Notice the bottom of the door sill is level with the trim and about 5 mm lower.
More in my next post.
Gordon Raymond
  #53 (permalink)
Old 04-13-2008, 03:34 PM
Here are some more Einar, first the side trim picture, then a couple out of focus, that try to show both, the upper and lower captive nuts for the grill mounting screws. These are 5 x .8 thread four sided nuts, held in three sided boxes so they can move around to center the grill but not turn. Then a picture of the screws, 5 x .8 x 25 mm, the top a blued flat head, the bottom a chrome oval head. I hope these will help you get the nose back on with less guess work!
Yes my wheel arches are rolled on wire, english style, or as Ferrari does it. As I have only seen one other factory example like this, I felt Terry Rushbrook's measurements would be more accurate for the majority of these cars. My car also features lighter gauge sheet metal from the cowl forward than in the rest of the car. The other car with rolled on wire wheel arches also had the thinner front end body work. I saw this other car in New York, about 40 years ago. It was painted a light straw yellow.
Gordon Raymond
  #54 (permalink)
Old 04-13-2008, 04:24 PM
Thanks again Gordon!
I tried the nose on using steel sheet strips and pliers. The strips makes sure the missing piece can be made with flowing lines. They should have at least 3-4cm overlap on each of the panels to be aligned, and wide enough to not be bent too easily.
I was not able to make the upper portion flow and get what I thought was a sensible slant on the grille. The bumper support tubes did not end up where they should be. On closer inspection, the right tubes have taken a hit and made some dents in the U shaped front frame. Some previous repair was made where these tubes attach to the frame. And as usual the welds looked like chickenpoop. Which made it easy to take it all out. That kind of weld lets go pretty easy. Once open, I found the whole frame filled with something appears to be excellent for planting flowers in. Although no holes, the forward facing part of the U frame looks both beaten up and crusty, so I'll make a new part. The part with a red circle around it is the support for the steering endstop.
I think you should be aware of it and where it is, so you can drill a hole above it and in the bottom of the U frame. Then flush out the crud. A rust treatment will get nowhere if it's full of dirt. Let dry thoroughly (several hot and dry days) then spray in very thin Tectyl. There is one with consistency like CRC with excellent creep abilities. Let dry for a couple of days and follow up with a rust treatment that flows easily. That support inside there will prevent a wax like treatment to get past it.
I'll take some pictures after opening the frame so you can see how it looks inside. Hopefully that will help you improve your rustproofing. You can make holes in the frame if you plug them with plastic plugs when done.
1996 960 3.0 24V
1988 780 Bertone
  #55 (permalink)
Old 04-15-2008, 04:36 PM
And here's how it looks inside. It was almost completely filled with crud. And then with some welding being done some of it had taken on a consistency it's hard to describe unless you saw the film "Alien"!
If you see some use in the pictures, grab them now. I may lower the size and/or quality to save space on the server if needed. If you have questions or need measurements, ask now before I close the frame again. I will keep patterns that I make in case need arise in the future. That will be the front part of the frame wrapping under and back.
What is not so easy to see in the pictures is that since it obviously took a hit in the front at some point in time, the remaining part of the frame is (was) bent back a bit. The red circle highlights a crack that needs to be welded as it is part of the support for the steering box. Due to the vibration and stresses in this area the crack will be welded using OxyAcetylene. The crack have probably developed because the repair was done more to restore the looks than the load and stress carrying capabilities of the frame in this crucial area.
So far this has been mostly ripping things off. Pretty soon now there will be some parts going back in. I look forward to that of course. But I just cannot leave these things I find on my way. It's not just the goal, but also the lessons learned on the road there that makes this worth doing.
BTW: In one of the pictures you can see the roof of a 1964 Ford 350. If you know any resources on this car, contact me in PM or email. We have some unanswered questions and part needs for it. It belongs to my friend that owns the workshop.
1996 960 3.0 24V
1988 780 Bertone
  #56 (permalink)
Old 04-19-2008, 04:16 PM
Finally some parts going back in!
Not that I'm done cutting out yet, but still it's rewarding to see something going back in. This is the corner of the front frame that I wanted to restore to full strength. The corner piece have too much shape to do in one piece. At least not for any valid reason. So here is the first part:
And after the second part is welded to it:
It was welded in using OA and the bracket for the steering endstop was MIGged in place.
Just a touch with a grinder on the outside where the MIG cooked through and when painted the weld seam should not be easy to find. If you cannot see the full penetration of the weld, it was too cold and could be just "glued" in place ready to fall off when stressed.
The butt weld where the new piece meets the old steel is hammered after welding to stretch out the crimp caused by welding. That will leave it with very little stress in the steel. This was not the case as it was. When I cut out the corner the cutout piece would not fit right in. That's a sure sign this corner have been under constant stress.
1996 960 3.0 24V
1988 780 Bertone
Last edited by ESjaavik; 04-22-2008 at 10:56 AM. Reason: Corrected TIG to MIG. I'm sure some of you spotted that one already!
  #57 (permalink)
Old 04-22-2008, 10:51 AM
I was contacted on email referring to this thread. I hope it's OK to copy this to the thread without identifying the person. I do that since it seems I may have written something that might not come out as good purchasing advice. And anyway it was a very good question.
We have gas, (O/A), Arc & MIG, (Miller 151 Mig-matic) at home. I see on the BB you recommend TIG, rather than MIG – why is that ? The reason I ask is that TIG is very expensive {local price deleted} I understand is has to do with heat being able to work the metal afterwards.
And my answer:
Actually it's mostly because I have OA, MIG, TIG and stick, and I point out where I will prefer each of those. It's not that it cannot be done with one or more of the others. TIG is very nice for getting a nice weld with little warping and very nice to deal with after welding. MIG is a ***** on places where you need to straighten it and planish afterwards. What you gain in it being very quick when welding you waste on grinding and straightening afterwards. The MIG weld is very hard, so damaging the hammers and dollies. And the metal on each side of the weld will be more brittle because of the high welding temperature and rapid cooling.
If I were forced to give up all welding methods except one, it would take me 2 seconds to decide on the OA. It will put in more heat and thus warp more, but it (the sheetmetal) will stay very soft and workable. And if you have experience using OA, it will be much easier to master TIG when/if you get there.
I suggest you cut a lot of coupons let's say 15x30cm with one very straight edge (use a file if you must) and weld 2 of them together at those edges. Tack at 30-50mm intervals, grind if necessary and hammer (+dolly) those until the sheets are completely straight again. Then fill in between them and grind/straighten again. When you can do this every time and end up with a sheet that have no waves or oil-canning, you're ready to tackle the car body. If you can do it in less than one hour, buy yourself some beers, you deserve it.
And I might add:
So yes, it very much has to do with the ease of working it afterwards. But I'm willing to spend on equipment not just to get the job done and done good, but also to learn using it. I love learning!
One of the factors I forgot to mention is that OA is much less dependent on the weld site to be scrupulously clean. With MIG and TIG there must be no traces of rust, oil, paint or in short anything but steel within the heat affected zone. On old car bodies that very often rules them out because it is just not possible to get that condition. But very seldom is there one method that is the right one although there may be a preferrable one.
I just corrected the previous post too as I found I wrote TIG where actually MIG was used. Why? Because the closed box shape will make OA difficult with the heat being deflected back to the nozzle. The TIG machine was not close by but would have done it nicely. The MIG was there and in this place there will be more OA welding, so I'll run the flame over the weld to anneal the weld area.
1996 960 3.0 24V
1988 780 Bertone
  #58 (permalink)
Old 05-09-2008, 06:48 PM
Ian Evans's Avatar
update
Einar,
I can't speak for everyone, but I'm anxiously awaiting the next update...
Ian
  #59 (permalink)
Old 05-09-2008, 10:42 PM
pathung's Avatar
Black is Faster...
Einar, you lost me about 2 pages ago with the technicals of metal working, but I enjoy the pictures nevertheless
Patrick Hung
'59 Giulietta Sprint * '63 Giulia Spider * '67 Sprint GT Veloce
Costa Rica & Taiwan SNO Chapter Director
VeloceSpace Restoration Parts
Sprint Racer Build Photos
Vintage Alfa Registers
  #60 (permalink)
Old 05-13-2008, 02:57 PM
So I might as well type the text in norwegian then since you just look at the pictures?
Ok, let me show you how I plan to tackle the "missing link" between the front piece and the rest of the body. I need to know what shape it has. To record that I use a flexible tape pattern. Did I touch that base before? I think not. A couple of posts back you could see there is a piece missing and replaced by strips to hold it in place. Well that won't do, it's too leaky so I need a solid piece of the right shape and arrangement.
This picture shows the tape pattern I took off another Spider that I have access to. It have been hit in the nose, but not too seriously, so the shape is OK.
The stippled lines encompass the area where new sheetmetal is needed. But if it were to be made from one piece, some quite severe stretching would be needed where the front meets the headlight opening. It has to be made in several pieces. I'm sorry I did not take a picture of the tape pattern lying on a flat surface. That makes it really easy to analyze where it needs stretch and where it need crimp. I have one of the bootlid though. It reveals that most of the shape (strech in this case) is in the rear 1/3. Figuring that out using contour patterns would either require a huge experience or lots of scrap.
Making the Z-shape along the hood opening would make it much more difficult. So let's first make that opening, as a really easy piece is needed to boost morale.
Ahh... that was easy. Now I feel better and ready for a more demanding piece. Here it is, held in place by clamps.
That was first of May, and then suddenly summer arrived. And with it distractions like the lawn, weeds, cleaning the place of crap, and admittedly some plain basking in the sun. Then I also need to get my Spyder ready for summer. It needs a new clutch.
1996 960 3.0 24V
1988 780 Bertone
