Giulietta Berlina Body Question - Alfa Romeo Bulletin Board & Forums
post #1 of 16 (permalink) Old 07-30-2016, 09:37 AM Thread Starter
Worti's Avatar
Hi Guys
got some problems on the Body..
Somebody know a Source to get the metall sheet for the left and right side of the body? Im mean that part between the Nr.4 and the Nr.15. Nr.15 is connected with one screw to that part. Looks like is to much for me to handle it....
Also someone can take some picture about the side sill? I have no idea how they was connected 1960.
Would be nice if someone could help
regards
Rolf
164 3.0 V6 24V Super Jg. 93 / 164 3.0 V6 24V Super Jg. 95
164 3.0 V6 24V QV Jg. 94 / Giulietta Belina TI Jg. 60
Worti is offline
post #2 of 16 (permalink) Old 07-30-2016, 11:50 AM
AlfistiSA's Avatar
Hi Rolf
I'm not quite sure of which parts you need pictures of, I think you are referring to the panel where the door hinges are welded to ?? I will take pictures of our Series II Ti tomorrow, including the A posts and the sills.
Part 15 is a thin metal cover plate which fits in the hinge area of both front doors, it's a decorative plate and has no function other than to make the hinge area look better. The U shaped cut outs on the side go around the hinges and the slot in the centre takes the check strap. It is held on with several screws = #16
Mine are off the Ti at the moment so I can take close up pictures of them if you need ??
Ciao
Greig
'61 RHD Ti AR10109*00647
AlfistiSA is online now
post #3 of 16 (permalink) Old 07-30-2016, 01:36 PM Thread Starter
Worti's Avatar
Hi Greig
my mostly biggest problem are the side panels..
(Black Lines). That if there is a source or someone that can make it i would buy.
Then i need some help on the side sills, no idea how it looks original. (Red Lines)
Both side are fixed some time ago in italian style..
Thanks a lot.
Rgards
Rolf
Worti is offline
post #4 of 16 (permalink) Old 08-04-2016, 12:23 PM
maxpayne1961's Avatar
Hello,
I have just finished the restoration of my sedan
you can view the photos on my site
A.R.G.Ti Cronologia pag.10
Best Gegards MAX
maxpayne1961 is offline
post #5 of 16 (permalink) Old 08-04-2016, 12:54 PM Thread Starter
Worti's Avatar
Hi Max
Thank you for the Link. I think i use your picture to find the right ash tray. I will follow your link, but start at page 1. Allways nice to see how other repair the rusty parts.
Best Regards
Rolf
Worti is offline
post #6 of 16 (permalink) Old 08-05-2016, 04:43 AM
you speak italian ?
If you need more detailed photos please ask. . .
Best Gegards MAX
post #7 of 16 (permalink) Old 10-31-2016, 09:24 AM Thread Starter
Worti's Avatar
Hi Max
sorry, not really.
Have you some measure between the rear door and the body. I have on both sides a difference from more than 1 cm in the corner . But i dont know if it is the door or the body because everything was repaired..
Can you send me some pictures from the rear wheelhouse in and out?
Best regards
Rolf
Worti is offline
post #8 of 16 (permalink) Old 11-01-2016, 04:06 AM
If you show me the exact measuring points,
control over my Giulietta and I send the measures.
P. S. Using an automatic translator from Italian to English
post #9 of 16 (permalink) Old 11-01-2016, 04:08 AM
Here you will find pictures of my restoration in high definition
Restauro Alfa Romeo Giulietta Max
Good Job
post #10 of 16 (permalink) Old 11-01-2016, 12:33 PM Thread Starter
Worti's Avatar
Buonasera Max
Grazie per il link
check the pictures, im sure wil be help.
i make some pictures on saturday with the positions.
buona serata e grazie
Rolf
Worti is offline
post #11 of 16 (permalink) Old 11-09-2016, 04:06 AM Thread Starter
Worti's Avatar
Hi Max
found my missing inch. Don't need the measure
Regards
Rolf
Worti is offline
post #12 of 16 (permalink) Old 11-10-2016, 12:10 AM
OK
good job.
If you need the Giulietta manuals you can send them in "PDF"
Regards Max
post #13 of 16 (permalink) Old 03-15-2017, 02:15 AM Thread Starter
Worti's Avatar
Hi Folks
need advice for the passanger floor. They have or haven't texture? in the Manual they have, in the car i have 3 new pannels and one original without texture.
Which one is the right one?
regards
Rolf
Worti is offline
post #14 of 16 (permalink) Old 03-17-2017, 09:56 AM
GTD
GTD's Avatar
Rolf
You use the word "texture" ... I believe you are referring to the ribs or beads that strengthen the floor panels.
Yes, original panels had those beads.
Your project is a great undertaking.
You must correct previous poorly done repairs before building the car in a correct manner.
Saluti !
Alfa Sapiens
GTD is offline
post #15 of 16 (permalink) Old 03-17-2017, 11:10 AM
Hi Worti,
My Giulietta III series did not have texture in rear panels.
In front panels yes ...
I have not found signs of previous repairs
