11-28-2008, 06:15 AM
George,
The flasher in my '62 Giulietta Spider operates just as you and Doug Depperman have described: flash with lights off, no flash with low beams on, flash with high beams on.
Originally Posted by Subtle
With the original steering wheel there were two buttons--an inner and an outer.
One flashed the low beam, which I thought should be re-wired to flash the high-beams.
I believe Subtle is referring to a 101 Giulia Spider which had the double button arrangement. George's car is a Giulietta with horn ring and single button for the flasher.
Bob Cess
'59 Giulietta Sprint
'60 Giulietta Berlina
'69 Spider Veloce
11-28-2008, 07:28 AM
Director BC Chapter SNO
Originally Posted by rcess
George,
My Spider was one of the late Giuliettas.
Bob
11-28-2008, 10:32 AM
And my Giulia has the double buttons, so I'm probably no help!
 Gordon Raymond
11-29-2008, 10:19 AM
George in Portland, OR
Reply from Lionel
This is what I heard back from Lionel. Looking at the wiring diagram I don't know why I should have to swap wires. The hi-beam works fine with the foot flasher. But, I will try his suggestion on Monday when I am back in the shop.
Hello George,
The flasher should work as follows:
Lights off - lights should flash when center button is pressed.
Lights low beam - should flash high beam.
High Beam - should have no effect because both high beam and low beam elements are on at the same time.
Troubleshooting the circuit:
Try inverting the headlamp green and gray wires one headlamp at the time while the other is completely disconnected. Please let me know of your results.
Hope you had a great Thanksgiving.
Regards,
Lionel
classicwiring.com - Home
11-29-2008, 10:37 AM
Ah HA! Now we all know how it's supposed to work!! Thanks (as always) to Lionel!
 Gordon Raymond
11-29-2008, 02:52 PM
Originally Posted by Andrew
Didn't the Giulias 101 wheels have a button and a ring around the button on the hub, rather than the Giulietta-style horn rim? The button would be the horn, and the ring would be the lights? Working from memory, not pics here.
Andrew
Andrew,
I don't know about the Giulia's only the Giulietta, but I think you are correct about the Giulia 101 wheels have a button and a ring around the button on the hub. I have a Giulietta and it has the separate chrome horn ring and a center light flashed button.
George
11-29-2008, 03:32 PM
Trained Professional
With all due respect to Lionel, the wiring diagram and the fuse designations in Giulietta owners manual #772 clearly show that the headlamps flash on LOW beam, a common Alfa practice for many years (at least through the 115 USA cars).
Series 1 Euro 1750 GTV
Series 2 USA 1750 GTV
Series 3 Spider Veloce
11-29-2008, 03:56 PM
Thanks papajam, that's the way the wiring diagram shows it too -- low beam activated center button. I would prefer the button activate the hi-beam instead; much more useful.
George
11-29-2008, 05:07 PM
Originally Posted by alfabits
I would prefer the button activate the hi-beam instead;...
Piece 'o cake. Remove the 1.0mm gray wire (as opposed the 2.5mm gray wire) from the top of fuse #7 and connect it to the top of either fuse #5 or fuse #6.
11-30-2008, 10:13 AM
Perfect solution. I will try it, looks like that should work.
George
12-01-2008, 05:56 PM
papajam, that was the solution! Thanks.
So Giulietta owners with original steering wheels and those of you who have the "steering wheel center button" flashing only the low beam, here is the solution to change it to work the hi-beam. In the fuse box, remove the 1.0mm gray wire (as opposed the 2.5mm gray wire) from the top of fuse #7 and connect it to the top of fuse #5. See photo of change wiring.
Now when headlights are off or headlight low-beams are on, the "steering wheel center button" flashes my hi-beams.
Cheers,
George
George Kraus
Portland, OR USA
1960 Giulietta Spider Veloce
Concours Winning Restoration:
Collection: George Kraus Restorations
My Veloce restoration nearing completion. - Alfa Romeo Bulletin Board & Forums
e :: gekraus@comcast.net
12-04-2008, 02:18 PM
Skyline Drive
I just came back from a very spirited drive on "Skyline Drive" in the foothills just south of Portland in my Veloce. Beautiful clear, crisp day. Perfect to scrub off a little rubber on the pavement. God I love driving this car...
George
George Kraus
Portland, OR USA
RESTORATION PHOTOS :: Collection: George Kraus Restorations
ALFA BULLETIN BOARD BLOG :: My Veloce restoration nearing completion. - Alfa Romeo Bulletin Board & Forums may require signing in.
12-04-2008, 02:49 PM
George
Nice up here today as well, but it's my day to work.
However, if I took a drive through the twisties along Marine Drive it would be with the top down--and it is 43 F.
Bob
Bob
12-04-2008, 03:36 PM
Marine Drive Portland? Problem is Portland's Marine Drive has 30 to 50 mph winds today. That's why I went west.
George
12-04-2008, 03:42 PM
Marine Drive, Vancouver, B. C.
For an overhead view--Google Maps--for University of British Columbia.
Bob
