Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > Giulietta & Giulia (1954-65)
Old 07-31-2007, 01:07 PM
tiger0529's Avatar
tiger0529 tiger0529 is offline
750 Center Grill Repair Cost
Hello all,
I purchased a used original (brass), beat-up center grill quite reasonably off of ebay for my mother's 750 Spider and took it to a local bumper repair/rechroming place to get a quote. The grill got a tiny crack (small enough that I can cover it with a rubber trim *I know it's not original for the Spiders* if I decide to install it on the grill) at the edge right by where the emblem sits, and has a tiny hole (probably from hammering) in one of the side bars. Manager at the bumper place told me that those (a crack & a hole) cannot be fixed, and gave me a quote of 160USD for reshaping & rechroming. Does this sound reasonable, or would you need to see pictues of the grill as it is right now to answer the question? BTW, it's painted bright yellow right now.
Thank you in advance,
Taiga "Tiger" Inoue
1991 Spider Veloce/1967 Sprint GTV (in Japan )/1970 300SEL 6.3 (in Japan too )
My mother owns 25 alfas
Last edited by tiger0529; 07-31-2007 at 02:12 PM. Reason: Trying to get the characters un-italicized... Never mind, I got it working.
Old 07-31-2007, 01:17 PM
Gordon Raymond's Avatar
Gordon Raymond Gordon Raymond is offline
Thumbs up Chrome grill restoration (brass)
The old brass grills can be easily repaired if done by a craftsman with motivation. Unless careful attention to detail, the can come out wavy! Also critical, is that the grill curve is correct to fit the cars nose. Has the car had bodywork?
Quality chrome work is no longer inexpensive. If you wish the names of quality chrome restorers. send me a PM, and I will point you in the correct direction. Gordon Raymond
Old 07-31-2007, 01:28 PM
ossodiseppia's Avatar
Encroaching Hypocrite
He's absolutely right. Before new grilles for Duettos were available, I sent ont out to get repaired. It cost more then the new ones are selling for today. In order for your new grille to be properly repaired it should be stripped down to the brass and all of the holes and cracks repaired. I would think that it could be brazed. If the grille is tweaked, the guy fixing the grille will need the car. The car will be his reference for getting the grille shaped properly.
I know a guy in Longmont that could straighten the grille, but he would need the car.
Check out my restoration
Old 07-31-2007, 02:09 PM
tiger0529's Avatar
Gordon and Osso,
Thank you for the advice. The car is in Irvine, CA right now with its body repaired and painted so I guess I will get it done in CA nearby where the car is. Without your advice, I would have wasted $160 and turned the grille into a display-only piece. Thank you very much.
Taiga "Tiger" Inoue
