07-17-2007, 06:29 PM
Originally Posted by cstlhn
It is a plastic media. The shop also sprays the car in a self etching primer immediately afterwards.
George is correct. The car has been previously repaired several times. Greig gave me some good leads, as did others, for parts. I have many business contacts in Italy so I will try them Monday.
David
David,
what shop are you going to?
07-17-2007, 07:18 PM
The company is called Longwood Metal Finishing in Deering, NH. Steve Holdner is the fellow I am dealing with.
The bodyshop I am using has worked with them before with good results.
www.longwoodmf.com
David
07-17-2007, 08:01 PM
awesome link, thanks. Hopefully i can afford to take the GT there when I'm finally ready to start in with the metal work.
08-08-2007, 09:45 AM
I should probably get this thread moved to the restoration section but until then;
Photos of the car now back from media blasting and at the body shop. It has a coat of primer to keep it from rusting (further). The sides are better than originally thought but the right front fender is horrible! I am looking for sheet metal.
08-08-2007, 01:13 PM
Hi David,
Here's a picture of a NOS Giulietta Spider front panel that I'll be selling for a friend. As you can see, the grill openings, curves and headlights are significantly different between the Bertone Sprint and the Pininfarina Spider so as Greig said, forget it. Good luck in your search/repair and keep us posted. Can anyone tell me if I've got a 750 or a 101 Spider front here?
Bill Sinclair
08-08-2007, 07:29 PM
Black is Faster...
I think that the front clips are the same for 750/101s, no?
Patrick Hung
'59 Giulietta Sprint * '63 Giulia Spider * '67 GTV
Costa Rica & Taiwan SNO Chapter Director
Vintage Alfa Registers
08-09-2007, 05:19 AM
"I think that the front clips are the same for 750/101s"
Si
[COLOR=DarkRed]Alfista Sapien[/COLOR]
08-09-2007, 03:48 PM
CSTIHN,
email me at alfas07@I know of a front clip for a Sprint could even be a Veloce.
11-01-2007, 08:36 AM
I spent some time with a hammer and dolly and got the nose in reasonable shape. I am waiting for a right front fender from Anacortes, WA.
11-01-2007, 11:24 AM
I've seen worse than that straightened out by good body guys.
Andrew
11-01-2007, 12:48 PM
Sprint front fender
Cstlhn,
Would there be a left front Sprint fender in good condition in Anacortes, WA for sale as well? I´m interested in that case.
Dennis,
´62 1600 Spider
´62 1600 Sprint
11-01-2007, 01:41 PM
Originally Posted by concept 101
Cstlhn,
Dennis,
´62 1600 Spider
´62 1600 Sprint
Dennis,
The photos I was sent only include a r/f fender from a Sprint that was totaled. It was the only salvagable part on the car. I do know know of a car in Massachusetts but have not been able to convince the owner to sell it and it is rusting fast.
Andrew,
Thanks for the compliment. There is about 6 hours work there and if I was a Pro the boss would have canned me for taking so much time. I found it relaxing and it was great fun to watch it take shape, that is what hobbies are supposed to do. I plan to post more photos of the project as it progresses.
David
11-02-2007, 01:23 AM
Hi cstlhn
Great work, well done. The trick is to shape the sheet metal to fit the trim & not try to bend the trim to fit the sheet metal as the trim kinks & is next-to-near-impossible to repair..... or very expensive.
The Sprints got a very thin "U" shaped rubber around the centre grille, it hides a multitude of sins at the trim to body joint. In contrast, the eyebrows were fitted metal to metal.
I did buy enough "U" rubber to do all the trim on my car - personal preference.
Keep those repair pictures coming.
Ciao
Greig
11-02-2007, 07:54 AM
Sprint fender
Got your message David, thanks anyway...
Dennis
11-02-2007, 02:16 PM
Here are the photos of the fender;
