12-12-2007, 10:15 AM
Greig,
The section appears to be similar as you say and I have been thinking about having a section run to be made up into the frame. It might be of interest to see how the section varies and if one section could serve both models. I would have thought that Alfa would have used only one! But who knows at this point in time? Do you have free access to both cars? Perhaps you could make a template for comparison.
regards
Stuart
12-12-2007, 05:27 PM
I am converting my '59 Sprint Normale into an Allegerita clone for Historic racing. I was wondering if anyone reproduces the plexiglass side windows and frames? I also plan to make Plexiglass front and rear windscreens using original glass to make molds.
Before doing so I am wondering if these are available?
David
12-12-2007, 06:52 PM
Old Photos
My dad and I were looking through his old photos and found this one of the car after its last repaint to resale red. The photo clearly shows that there are no window frames. He also remembers there being a "Conrero" badge or sticker on the front fender, and he indicated that this was a "hot-rod" version of this particular model, with Koni adjustables and a tuned Abarth exhaust. He can't remember any more specifics. The car currently has a normal 1963 Giulia TI 1600cc engine in it, replaced after the original 1300cc block cracked. I have pictures of the original cylinder head off the car with an exhaust valve completely burnt up, also showing the original Webers.
I keep finding more and more out about the car, and I owe a lot of it to the expertise and helpfullness of the Forum members. Thanks!!
Dan Davis
Counting down to Dec. 28th (Resurrection Day)!
12-13-2007, 12:28 AM
Hi Mike
The first 50 Confortevole's were fitted with these frames, I'd guess that there may have been some left-over frames at the end of the lightweight run, (+- 600 cars), and Luigi-on-the-line fitted them to the first 50 Confortevole's - the window glass is smaller to fit into the aluminium channel.
I visited the friend with the blue Confortevole this morning & looked at the car, the frames are incredibly thin & while I haven't compared them physically to a Lightweight, they may in fact be the same frames, but with a different insert to take either wind-up glass or sliding plexiglass ??
One day I'll get to seeing a genuine lightweight, but as far as we know, there is only one lightweight left in South Africa & the owner is reluctant to let people see it.......
Ciao
Greig
12-13-2007, 10:56 PM
Registered Driver
Dear Stuart Zagato and Greig AlfistiSA,
The Photos Greig showed remind me of the first time (of 4 lightweights I've worked on) I noticed that the aluminum channel was installed, as Greig's photo of the red SVA shows, with the 'big lip' inside rather than outside as one would expect. Odd, but that is the only way it will work! I have seen other SVConfortovoles without frames, thank you Dan davisfamily is one more, but the photos of your car with frames Greig are the best so far. Note the 'big lip' is outside on the roll-up window car!
Dear David cstlhn, please enjoy your Sprint! It's a wonderful motorcar. It doesn't need to pretend that it's a Ferrari. It's different (and rewards a skilled driver better). It's your choice, but I'd stop at making it an 'abnormale' 1400. And safety equiptment for race track use. It is too easy to get carried away with hop-up improvements.
Dear Patrick Hung, how did Lionel Velez's motorcar SVConfortovole 1493E*06611 escape your list? Did you notice the lists compiled by iicarjohn ? Hope to see some of you on New Years Day for the Anti-Football run!
Cheers, Laurence of Berkeley
12-14-2007, 08:09 AM
Black is Faster...
I don't know! Gotta get back on the ball here....
Patrick Hung
'59 Giulietta Sprint * '63 Giulia Spider * '67 GTV
12-14-2007, 08:38 AM
Laurence,
I appreciate your note and advice. The Sprint I purchased this summer was down and destitue. No engine or transmission, rusted out floors, no interior, and three different types of wheels.
Having stood on the side lines for the past 20+ years and watched all the cars I have worked on enjoy Historic racing with their respective owners I decided it was time. So rather than hunt for period correct pieces to restore this car I am building what you guys would call an "abnormally".
The Ferrari world was begginning to sour my love of cars in general. Like the Corvette people twenty years ago I believe the Ferrari weenies have gone to far. Having said that I hope to own and restore a Giulietta TI someday to original.
David
12-14-2007, 09:27 AM
David,
If its a TI you really want try Classic Driver - HOME there is one for £9k which seems to be more than reasonable. No connection.
seasonal greetings.
Stuart
12-15-2007, 05:07 AM
Giulietta Sprint Veloce 1600
So, if what my dad remembers is correct, in 1973 or 1973 he and his brothers put in a 1600 out of a TI. I understand that those came with 5 speeds(?). Would that be the only option, or could they have put in the 1600 using the original 4 speed? I am just hoping that the Weber 40's are still there somewhere...
You must remember that the car is around 250 miles away, with no way right now to even open the doors because of the decrepit barn in sits in!
Dan and davisfamily
ddavis11@aug.edu
12-15-2007, 05:10 AM
SV 1600, Conrero
Also, does anybody hae any information on Conrero in Turin? My dad says that they tuned the car, but the contact I have with the company says they lost a lot of records in what sounds like a flood in the '70s or '80s. Are there any tell-tale signs that they have had a part in the car at some point. My dad seems to remember a badge on the car.
Dan and davisfamily
ddavis11@aug.edu
12-15-2007, 06:18 AM
There will be a number of tell-tale signs in/on the engine, but if the original "Conrero" engine has been replaced there will not be too much left to see. The Conrero badge was in effect his name in capital letters with the word Squadra above, rather than a symbol or a motif. I am grappling with similar problems with my Conrero Special (name used by Jean Rolland on the entry forms for the Mont Ventoux hill climb in '59 and '60) which has full and comprehensive body, frame and suspension modifications for competition and so far have not even been able to get a peep out of the modern iteration of the Conrero Company. Perhaps you could let me have your contact name?
Stuart
12-16-2007, 02:26 AM
Originally Posted by davisfamily
So, if what my dad remembers is correct, in 1973 or 1973 he and his brothers put in a 1600 out of a TI. I understand that those came with 5 speeds(?). Would that be the only option, or could they have put in the 1600 using the original 4 speed? ddavis11@aug.edu
If your 1600 came out of a Ti (assuming it's a Giulia TI?) it would have had a 5 speed box.
My 101 series Giulia Sprint which was originaly fitted with a single-carb 1600 has been retro-fitted with a 105 series 1600 with twin Weber 40s. It's a compact fit but nothing rubs. To make things tighter, it has been converted to RHD (by Ruddspeed in England - there is a Ruddspeed plate on the firewall with the serial no. 158RD) which means that the steering column has to fit under the Webers. The steering column has two universal joints to effect this clearance.
Now:
64 Giulia TI Super replica (still building after all these years...)
62 Giulia Sprint 101
Fiat 128SL (a bit dead)
Then:
1967 Giulia Super daily driver
1966 Giulia Super (part rebuilt)
1972 Berlina 2000 parts car (LSD donated to TI Super project)
1969 1750 GTV (oops, forgot about that one)
1965 GTA (OK, it was a slot car..)
12-16-2007, 02:40 AM
Track down a copy of Alfa Romeo Veloce - The Racing Giuliettas by Donald Hughes & Vito Witting Da Prato (Haynes Publishing Group, 1989). It has some excellent information on Conrero (and other Giulietta tuners including Facetti). Some tell-tales of Conrero engines are the presence of a copper seal rather than standard head gasket between head and block (apparently Conrero's milling of the mating surfaces was almost perfectly flat) and the 'Conrero window' in the airbox - made by cutting a large hole in the side of the airbox directly in line with the carby throats, and fixing some mesh to the opening to keep out boulders. This complied with the letter of the regulations, if not the spirit ... but maybe it met the 'do whatever it takes to go Veloce' spirit better than most mods?
Now:
Then:
12-16-2007, 07:03 AM
Greig,
I have been going through my photographs of Lightweight door and have come across this which is taken from a similar angle to that of the blue Confortavole. It seems to me to be an identical section, but I don't know. What do you think? My original perspex side windows are less 3mm thick which would then allow them to slide past each other within the frame thickness. If I do have some section produced are you interested?
Stuart
12-16-2007, 12:32 PM
Father now says that "famous racer" Paul Spruell put the Giulia TI 1600 into the car. Apparently his brother knew of him while in Atlanta, and he had this engine sitting around the shop! More to come...
