Copiglia Hose clamps - Any tips? - Page 2 - Alfa Romeo Bulletin Board & Forums
 2Likes
post #16 of 28 (permalink) Old 05-27-2015, 07:50 AM
Tom F2's Avatar
The tool for tightening the cotter pin types consists of a partially flattened tube with a t-handle welded to one end. I had one when I worked in a Fiat dealership, many moons ago. The hex-headed ones used on the 750 cars are much nicer, IMHO, not least of all because they can be tightened with a normal socket.
The only drawback of these clamps, for our Giuliettas, is that they should not be reused, though the pin and clasp can be recycled for use with fresh banding.
The perfect is the enemy of the good. Voltaire
Tom F2 is offline
post #17 of 28 (permalink) Old 05-27-2015, 02:30 PM Thread Starter
I found a couple of photo's of original clamps in situ and it appears that it isn't necessary to wind the band around twice. Once should suffice, although twice probably helps seal a bit better!
Thanks for the info on the special tool. The end of an allen key through the eye works fine though.
timdaw is offline
post #18 of 28 (permalink) Old 05-27-2015, 08:53 PM
Tom F2's Avatar
Tim, I can't cite any SAE studies for you, but I think that the double loop is important to a secure connection with a Copiglia style clamp.
Tom F2 is offline
post #19 of 28 (permalink) Old 05-28-2015, 01:21 AM Thread Starter
Thanks Tom. Here is a pic of an original installation on an air hose.
However, that's an air hose where the sealing isn't quite so critical. I agree that 2 turns would be better, and also helps the strap to tighten evenly around the circumference. I'd go for that on the water and fuel hoses.
timdaw is offline
post #20 of 28 (permalink) Old 05-28-2015, 04:07 AM
Chris1750's Avatar
Here are a couple of original clamps from my car - one for water and one for fuel. Both are double looped.
For air, you're right - not so critical.
Chris
1970 1750 GTV
1957 Giulietta Spider
Chris1750 is offline
post #21 of 28 (permalink) Old 07-19-2016, 01:54 PM
IRONBLOCK's Avatar
This is an old thread with some good information.
One day I noticed that the open end of one cotter pin from a Copiglia hose clamp set exactly fit in the loop end of another cotter pin. One cotter pin works well to tighten another although you can apply more torque with a longer tool, like a small screw driver. Also, the banding material from a larger hose clamp can be reused on a smaller hose clamp connection, if the coiled end is removed.
I have found that original connections that hold a liquid (coolant or fuel) should have the flat wire 'doubled up', while air ducts only need one loop of flat wire.
Mark
IRONBLOCK is offline
post #22 of 28 (permalink) Old 07-19-2016, 03:45 PM
VabeneGTV's Avatar
I know a clamp is missing, but here is a photo of a fairly recent installation. Fran
VabeneGTV is offline
post #23 of 28 (permalink) Old 07-20-2016, 10:33 AM
Send a message via AIM to john.harrill
First time I used copiglia clamps, I was certain they would leak...they didn't.
Plus, they just look cool.
Currently Owned:
1957 Giulietta Spider (Maria - Fabrication in progress)
1988 Quadrifoglio (Tony)
1987 BMW 653CSI (Gustav)
2002 VW Passat Wagon V6
2012 VW Tiguan SEL 4-Motion
Gone, But Not Forgotten:
1966 Giulia Sprint GT
1994 164LS 5-Speed
Working on:
1959 Giulietta Spider - Restoration
1967 Fiat Dino Coupe - Restoration
john.harrill is offline
post #24 of 28 (permalink) Old 04-26-2017, 08:20 PM
Raimondo's Avatar
Copiglia hex type clamps
Originally Posted by timdaw View Post
Thanks for the getting the thread back on track guys.
The kit came from Alfastop in the UK: AlfaStop - passionate about Giuliettas (vintage Alfa Romeo Spares/Parts) It contains a roll of the 9mm strip to cut to size, together with 25 clamps and cotter pins. It's the size suitable for the air and water hoses, not the fuel hoses.
Tim,
Reviving this thread...
What width band should be used for fuel lines? Would a double-banded 9 mm not work, if a more narrow band could not be found?
Any source for the hex head portion of the clamps?
Ray
Oklahoma SNO Alfa Chapter Director
'64/66 Giulia Spider finally back in the garage and painted
'75 Olandase Blu Alfetta Sedan 2.0 & '88 Red Milano Verde; both long gone and dearly missed
Raimondo is offline
post #25 of 28 (permalink) Old 04-27-2017, 02:29 AM
VabeneGTV's Avatar
5 mm bands for the fuel lines.
post #26 of 28 (permalink) Old 04-27-2017, 03:13 AM
Raimondo's Avatar
VabeneGTV,
Do you know of a source for 5 mm width band?
Ray
Raimondo is offline
post #27 of 28 (permalink) Old 04-27-2017, 11:02 AM
I buy 5 mm width hex headed Copiglia clamps from Scott Gray. I do not know where you can buy the cotter key fasteners, but I think that you can use a cotter key and cut it too length.
kuni123456 is online now
post #28 of 28 (permalink) Old 04-27-2017, 01:12 PM
Restoration Supply Company has both the strapping and the ends in 5 mm and 10 mm sizes.
Joe
jkbartusek is offline
Replace with
