Motomille
The answer is YES, your '59 will have the "interim suspension", looks like the 101 style, but is slightly lighter in construction.
Your '59 will accept the later style suspension, try source from a '61 model upwards, then you will ensure that you have the most robust A arms.
Rear axles are a straight swap, the later 101 trailing arms are more robust, with bigger bushes than the early 750 ones. The later style will fit on your '59.
Sprint / Spider & Ti suspensions are all the same, only the spring rating, length & number of coils is different.
Ciao
Greig
