Old 10-08-2009, 10:07 PM
Alfamel's Avatar
Help with Broken Window Regulator on my '62 Giulia Spider
My driver side window regulator moves the window up and down. However, the "wheel" that rolls back and forth on the window rail is worn and pops out repeatedly, rendering the window stuck in whatever position it was when the little wheel pops out.
I haven't yet found a replacement window regulator; but, mine works except for this little wheel. Can this be repaired. Does anyone know of what can be bought to be welded in as a replacement for this little, fragile part?
Help and advice, please.
Mel
'62 Giulia Spider; '69 Boat Tail Just Arrived
'74 GTV
Old 10-08-2009, 10:12 PM
pathung's Avatar
Black is Faster...
I wonder if a plastic wheel for a screen door at your local hardware store might work? I haven't looked at my regulator, so I might be way off!
Patrick Hung
'59 Giulietta Sprint * '63 Giulia Spider * '67 Sprint GT Veloce
Costa Rica & Taiwan SNO Chapter Director
VeloceSpace Restoration Parts
Sprint Racer Build Photos
Vintage Alfa Registers
Old 10-08-2009, 10:16 PM
Alfamel's Avatar
The real problem with this replacement is that the "wheel" mounts on an "axis" that is welded to and through the regulator arm.
'74 GTV
Old 10-18-2009, 06:23 AM
I had a similar problem on my 62 spider, I turned a new "wheel" out of aluminum, works great.
Dennis
Dennis Skraba
73 Spider, 68 1300JR RHD, 62 Giulia Spider
Old 10-18-2009, 09:35 AM
Alfajay's Avatar
Mel:
This reply isn't going to be very satisfying, because despite doing some research, I haven't found your solution. But here's what I know:
Back in the mid 1990's when I restored my Giulia, I bought new replacement nylon wheels. My memory is that I got them from Centerline - certainly from one of the US suppliers, because back in those pre-Internet days, I was only buying parts domesticly. However, a quick look at the Centerline and IAP catalogs did not turn up the nylon wheels - you could do worse than calling those companies and asking if they still (or ever did!) carry them.
I also did a quick search of the British and German parts suppliers, but again came up empty. If all else fails, AFRA in Milan would be a likely source, though they are a bit difficult to deal with for so small an order.
You did not specify if the nylon wheel is your only problem, or if the shaft it mounts to is also bad. You wrote "...anyone know of what can be bought to be welded in as a replacement..." which sort of suggests that the shaft is bad too. On my Giulia, I welded standard metric bolts to the arms to form the axles. I started with a long bolt, and used a die to adjust the location of the threads so that the part the wheel rotates on is smooth/unthreaded, and there is just a short section of thread where the securing nut mounts (did that make sense?).
'63 Guilia spider
Old 10-18-2009, 04:38 PM
Alfamel's Avatar
It is just the nylon wheel that is worn. The rest of the regulator works properly. Anyone with ideas on a source for replacement nylon wheels for the regulator?
'74 GTV
Old 10-18-2009, 05:44 PM
rcess's Avatar
Alfa Ricambi used to have replacement wheels, but that was some years ago.
Bob Cess
'60 Giulietta Berlina
'62 Giulietta Spider
'69 Spider Veloce
Old 10-18-2009, 06:22 PM
Alfajay's Avatar
Well, probably that's where I bought mine in 1993 or so - I was buying a lot from Ricambi back then.
You could do worse than checking with Alfa Ricambi - they still run ads in "Alfa Owner" - try 800 225 2532.
'63 Guilia spider
