Old 08-23-2009, 11:23 AM
101 sprint coupe trunk will not stay up
Hi
Can someone post a couple pictures of the mechanism that keeps the trunk open on a 101 sprint coupe? I am probably missing something on my car. I have the rod with the spring , but noting to stop it from closing.
Help needed. If someone has the necessary hardware for sale , I would be interested.I am also looking for a front grille and the right side vent grille.
thanks
Herve
Old 08-24-2009, 05:18 AM
AlfistiSA's Avatar
Sprint Boot Lid prop-rod
Hi Herve
These are from two '57 Sprints and a ’55 Sprint, but the mechanism is the same, the end of the metal rod tracks in a "U" shaped channel welded into the underside of the boot lid, this channel has a small "punched" dent in it, which will accommodate the end of the rod.
As you lift the boot lid, the spring keeps the end of the rod in the channel and when the lid gets to the dent, the end of the rod fits into the dent & upon releasing the lid, the rod now hold the lid in the open position.
Of course Alfa being Alfa, I've seen punched dents, punched & formed “pockets”, little straps welded across the channel and welded lumps, all designed to stop the rod from sliding back down the "U" channel, unless the rod is mechanically or deliberately released from its "stop" position, by one hand, while lifting the lid slightly with the other hand – properly set-up, the end of the rod is once again held firmly in the channel by the spring & it slides down the channel as the boot lid is lowered.
A word of caution here, the support for the rod mechanism is taken by the middle horizontal brace under the rear shelf, below the rear window - this brace ties the vertical support panel, (in effect the 'backrest' of the rear shelf between the rear wheel arches & shock absorbers) to the underside of the rear of the body just below the rear window, directly at the point where the hinge of the boot support rod is located - if this is not welded firmly, the weight of the boot lid is only supported by the 3" strip of sheet metal under the rear window & will flex a lot, with resultant damage to paint.
If all is as Bertone intended, with the spring tension against the rod, the end of the rod will never come out of the channels and there will be no risk damage to the underside of the boot lid.
Hopefully this answers your question
Ciao
Greig
Old 08-24-2009, 10:30 AM
alfa sprint trunk prop
Hi Greig
Thanks a lot for a very informative and detailed answer. I can see the dimple that hold the prop in the channel has been some what flattened on my car. Thanks for taking the time and for your very nice pictures. If you need help with a 2600 don't hesitate to ask(I have done a nut and bolt on a spider)
Regards
Herve
Old 08-25-2009, 05:38 AM
AlfistiSA's Avatar
Hi Herve
Glad I could help, shout if there is anything else.
Missed a 2600 Berlina earlier this year - pity as it was a nice car
Ciao
Greig
Old 08-25-2009, 03:57 PM
GTD's Avatar
GTD GTD is offline
Glad your driving has improved!
Alfista Sapien
Localphone: Cheap International Calls
Old 08-27-2009, 02:26 AM
AlfistiSA's Avatar
Near misses
I set myself up for that..............
