07-28-2009, 05:04 AM
Confortevole "Restoration"
So, I guess it's my turn to begin a post describing what my dad, boys, and I are doing to the car.
I scratched off enough of the crackled paint to read the Bertone body number, 655871*A*. This is 750 E Sprint Veloce #06482. The car was originally Bianco Nube (cloud light blue) with navy blue and light grey interior, and was repainted by my dad and uncles in the late 1960s to resale red. The can of red paint is on the back shelf.
I bought it last week from my uncle for $1. He was the last owner of the car, although the four of them don't really know who owned it! They bought it in 1968 from an Italian-American airman on Moody Air Force Base in south Georgia.
Pictures to follow.
Dan Davis
'58 Sprint Veloce Confortevole "Resurrected"
07-28-2009, 05:34 AM
Yesterday my dad and I cleaned out the spark plug holes (twigs, acorns, rat nests, etc.) and took out the spark plugs for a quick visual inspection of the cylinders, pistons, and valves.
Today, we plan on draining the oil and fabricating a tool to spin the oil pump with new oil installed. Then we will try to turn the engine over manually. I may work on cleaning the inside out, too.
Dan Davis
07-28-2009, 11:24 AM
Oil pump is geared to the crankshaft. Put some Marvel Mystery Oil down the spark plug holes and let it sit for a couple of days. Drain the oil and change the filter.
When changing the filter, do not ...repeat...do not lose the metal plate that sits on the bottom end of the oil filter. It is essential for oil pressure.
You might get lucky and have the one with the retainer in the bottom so that plate doesn't fall out.
Manually rotate the engine using a large socket and extension bar or roll the car in gear to free up the rings. Charge the battery and spin the engine over with out spark plugs until you get oil pressure before starting.
07-28-2009, 02:11 PM
Well, after putting up some bulletin boards in my classroom, I drove over to my dad's to do some work. He had to go to the post office, and we couldn't decide if we wanted to pull the valve cover off to lube the upper end.
So, I decided it would be no time like the present to begin cleaning out the inside. Apparently, the passenger footwell was where the rats/squirrels used the restroom, and the area under the rear cargo shelf was their bed. It was full (from metal to the underside of the shelf) with acorns, pecans, and twigs and padding scraps. At least something was using the car while in storage! I filled up most of a kitchen trash bag with the junk, just on the passenger side.
I quickly used some vinyl cleaner to wipe the interior panels down, then go the call from my wife to race home (45 miles) and kill a huge snake outside our front door that my dogs were going crazy barking at. Problem solved, ready for another day!
Dan Davis
07-28-2009, 02:18 PM
An "after" shot. Still smells bad. There is also a rat nest in the headliner between the sunvisors. That'll be later. There is the other side for reference of what it looked like before. Oh, yeah, and the paint can!
Dan Davis
07-28-2009, 02:21 PM
Location: NYC, NY. The Spider resides on Shelter Island, NY.
"The car was originally Bianco Nube (cloud light blue) with navy blue and light grey interior"
Here's hoping you restore it to that color combo. Good luck.
1975 Spider (Long gone gateway drug)
1983 Spider (Dead: slowly parted-out on eBay)
1974 Spider (Body restoration only took 14 months  , now undergoing wallet evaporating full mechanical rebuild)
07-28-2009, 02:23 PM
Wow who would have guessed
"Apparently, the passenger footwell was where the rats/squirrels used the restroom, and the area under the rear cargo shelf was their bed. It was full (from metal to the underside of the shelf) with acorns, pecans, and twigs and padding scraps. At least something was using the car while in storage! I filled up most of a kitchen trash bag with the junk, just on the passenger side."
You must have some very advanced rats and squirrels if they are drinking Schlitz beer!
Good luck with the project. You have a great starting point!
07-29-2009, 04:28 AM
Dad drained the oil late last night. I don't have any indication about how much was in there, but it looks like a good color, not chocolate-milky or clear like it had water mixed with it.
Velocedoc, I am in "constant contact" with GTD, and he gave me the heads-up on the oil filter canister. We'll be careful with that.
Should we take the cam cover off the manually lubricate the valve train and timing chain before spinning the engine over? I know the timing chain can be reached through the oil filler, but...
How are the cam lobes lubed when running? Oil galley, squirter, other? We are beginning to prepare ourselves for electric starting (jumping the starter with a device suggested by GTD). Maybe this weekend? School starts next week, minus furlough days.
Dan Davis
07-29-2009, 07:36 AM
More photos.
Dan Davis
07-29-2009, 07:41 AM
More photos. This IS a genuine Veloce!
Dan Davis
07-29-2009, 08:18 AM
Dan, by all means pull that cam cover and do a bit of clean up. There's quite a bit of oil retained under the cams that you'll want to clean out. I do this with every oil change and refill this area with clean oil. You might even want to put some assembly lube on the cams in the event oil pressure doesn't come up quickly.
Why was the car laid up? Given that Spruell replaced the original 1300 about the same time it came off the road in the early '70s I'd guess the engine is good i.e. it doesn't have a blown head gasket or failed water pump. If the engine did go toes up I think you'll want to deal with that fault before expecting it to run again.
Mike
'60 Giulietta spider, '67 GTV, '02 S2000
07-29-2009, 08:32 AM
I'll try to find out. As you know, the history is part of the family story behind the car, but can be hard to "pin down." The Solex carb was off the car, maybe they couldn't get it to run right with the linkages for the Webers or something. The linkages are there but the car has a downdraft intake manifold. We'll see!
Dan Davis
07-29-2009, 01:20 PM
Looking good. That interior will clean up nicely. If it were mine I'd get some Kroil (or other rust penetrating lubricant) and apply a few drops/squirts to EVERY nut bolt washer pivot spring etc on the underside of the car the next time you go for a visit.
Am I in danger of mailing you the trunk 'airplane' any time soon?
Matt: 8,000 #'s of Italian steel comprised of: 59 sprint 61 SS 69 GTV 72 Fiat 124 Sedan + 57 NSU Prima 3KL & 74 Triumph Trident
07-29-2009, 02:44 PM
Go ahead and box it up. I'll send you the .wav or .mov file electronically!
Another thing I am working on here at the house is the trim. I think my mom would really appreciate me putting the trim on for it to look a little better in her garage. I have all the trim for the entire car, minus that mentioned above
Looking at my eyebrows, the studs look bent and pretty bad. Some of them are missing. There is only one full length stud. It looks like they are brazed in or JB Welded or something. It definitely looks different than the way the studs are fastened to the back of the hood spear. I am going to get some new threaded rod at $0.25 each. These are just tightened down behind the front body panels, right?
I got some trims screws and washers to put on the door panels. That will cover up the inside of the door and make the interior look complete. How do the tops of the panels secure? Underneath the trim below the painted section at the top of the door? I'll throw the door handles and winders on for giggles.
My front bumper has the mounting plates still attached, but I don't know how they attach to the body through the holes in the front fascia. Can someone take a photo of that area? Remember, the car is 45 minutes away! I only have one mounting bracket for the rear. How do all the sections connect to each other? The curved outer edges have some brackets and bolts, but I don't see where to meet those up to the center section.
I'll put the grill up to the "Alfa bumpnose" and see if it fits enough to screw down.
I've gotta do everything I can to make my mom and wife happy, so the better the car looks, the better they feel. My mom noticed the difference a little while with some cleaner and vacuum made! Now just to do the driver side...
Did I mention that I live about 45 miles from my dad's house where the car is garaged? But I also drive pretty near him everyday for my work (Fort Gordon, Georgia).
Pictures to follow while I'm out in the barn grillin'.
Dan Davis
07-29-2009, 05:54 PM
I see how the rear bumper mounts together and with the bumper mount. Pretty self-explanatory now!
Any hints on getting old JB Weld off of dainty little chrome trim?
Dan Davis
