#31 (permalink)
Old 09-09-2009, 07:13 AM
davisfamily's Avatar
Where should I be heating? Around the hub and stud interfaces, I could guess, but is there like a "magic" spot I'm missing? Is there any concerns behind heating up the aluminum drum too much?
I am ordering some points and a belt today. Just one step closer to running!
Dan Davis
'58 Sprint Veloce Confortevole "Resurrected"
  #32 (permalink)
Old 09-09-2009, 07:43 AM
davestebs's Avatar
Dan,
The heater I used is a big thing made for heating garages etc. in a chilly Wisconsin winter. I heated the entire drum to probably not more than 150 degrees or so. I'm pretty sure the drums could get hotter than that during hard braking so I wasn't concerned. A hotter smaller heat source like a torch around the hub and studs didn't work.
Dave
'58 Sprint project '63 Spider driver '63 Appia Berlina
  #33 (permalink)
Old 09-09-2009, 06:22 PM
Looking at my Glenn's manual, I rotated the engine to TDC on #1 to remove the distributor for cleaning. The manual said to have the slot in the engine pointing "towards the front" of the engine. It is pointing at about the 1:30pm-2:00pm area, which I identified as firing at TDC of the compression stroke for piston #1. Does this sound right?
To the distributor, does the VJU41BR Bosch dizzy have those internal weights that adjust the advance? It has the vacuum advance canister on the side. Any other points to address while cleaning it out?
I'm saying it will run by Halloween!
Dan Davis
  #34 (permalink)
Old 09-09-2009, 06:42 PM
Originally Posted by davestebs View Post
Dan,
Big rubber mallets do wonders
  #35 (permalink)
Old 09-09-2009, 07:19 PM
davestebs's Avatar
Tried that too! Didn't work. Heavy metal hammer behind a wood block didn't do it either.
Dave
  #36 (permalink)
Old 09-11-2009, 04:25 AM
front brakes
My dad got the driver's side front drum off last night.
When he was adjusting the shoe adjustment tab on the passenger side, he noticed that it only rotated 1/2 turn. Is that normal?
I asked him how the rubber pieces looked and if there was any leakage evident. I'll let ya'll know!
Dan Davis
  #37 (permalink)
Old 09-13-2009, 06:09 AM
A few questions:
What is the finish supposed to be on the rear parcel shelf? What about the dash? Just regular paint? Body color, interior color, coordinating color?
Here are some more photos of the brakes. The driver's side came right off with some rocking back and forth. The passenger side is stuck at this point, with the shoes visible, but the drum only 1/2" off the backing plate.
I still have the question regarding the shoe adjustment screw. It only turns about 180 degrees in its rotation; is this normal? I would think it should be able to be backed out until it is removed from the backing plate. Is there something I'm missing?
Dan Davis
  #38 (permalink)
Old 09-13-2009, 07:39 AM
It's normal. The front brake adjustment is a cam that acts as a stopper. It only rotates a fraction of a turn. Note that there is one on each shoe. Make sure they're both released. The rear brakes are completely different.
As to the stuck drum on the other side, there's likely to be a ridge of rust at the edge of the braking surface and it's preventing the drum from sliding off. Moving the drum in/out repeatedly should erode the ridge enough (or the linings...) to let the drum eventually slide off.
  #39 (permalink)
Old 09-13-2009, 07:55 AM
A few questions:
Memories from my 1961 tell me it's a grey primer. But there's a piece of upholstery going there.
All visible surfaces, engine compartment, dashboard, inside of the doors were body color, EXCEPT the inside of the trunk lid (maybe all of the trunk) which was black (see the 1961 Road & Track road test of a white Sprint as an example). I believe the underbody surfaces were grey primer as well, more often than not covered with undercoating at one point or another.
This one seems pretty original, and close to yours:
BaT - The best vintage cars for sale online » Black-Plate Barn Find: 1958 Alfa Giulietta Sprint
  #40 (permalink)
Old 09-13-2009, 08:04 AM
The lower portion of the dashboard show the original color, cloud white. The upper portion is black. That correlates, but is the top of the dash wrinkle finish or smooth paint?
So the parcel shelf is just vinyl-covered and put into place?
My four required daily website checks, besides email: AlfaBB, giuliettas.net, capella.edu, and facebook. I have seen the blue car, and the white Confortevole sold around the same time on Matt's site!
Dan Davis
  #41 (permalink)
Old 09-13-2009, 08:36 AM
Here are the driver's side shoe and brake drum. I don't see any evidence of a rust ring. I will let my dad know about the other adjusting screw.
Dan Davis
  #42 (permalink)
Old 09-13-2009, 08:49 PM
[quote=davisfamily;792826]A few questions:
What is the finish supposed to be on the rear parcel shelf? QUOTE]
The parcel shelf should be covered in vinyl. If your interior is two tone, use the darker color to cover it.
  #43 (permalink)
Old 09-13-2009, 11:23 PM
PSk PSk is offline
Subscribed .
  #44 (permalink)
Old 09-14-2009, 03:23 AM
AlfistiSA's Avatar
Hi Dan
There are 2 snail cams per front brake on your car, (3 on the 3 leading shoe drums, but that is another discussion).
When crouched down, facing each wheel, with a size 18 spanner attached to the hex head of the snail cam, the upper portion of the spanner is just visible.
- On the LHS when facing the drum, you move the spanner anti-clockwise on both snail cams to loosen or release the shoes.
- On the RHS, when facing the drum, you move the spanner clockwise on both snail cams to release the shoes.
Pull the shoes off the drivers side - both hands & pull up & twist, then do the same with the bottom shoe - now look at the snail cams & you will see why they are called snail cams & exactly how they work & yes, the movement is finite as they stop against a pin.
I see you have taken the one drum off dry - don't be shy squirt lots of lube onto those shoes - you were NOT intending to re-use them now were you.......... back the snail cams off, penetrating spray & 2 largish screwdrivers & work gently & the drum will come off. Of course a large rawhide hammer also comes in handy. patience will be rewarded
If all else fails, pop the end cap off the front hub & remove the split pin & castellated nut & pull the hub off the front - gives you a bit more wiggle room & you can also pull the complete backing plate & drum off the car & take it to the workbench. Once again, patience will be rewarded.
The rear parcel shelf was originally done in Bertone's famous murky black primer, (which they obviously bought cheaply in bulk quantities), then it was covered in the darker of the 2 interior vinyls to match the rear shelf capping & the door panel trim - in your case, the dark blue, but the vinyl was glued in such a way as to clearly show the ribs on the rear panel - the easiest way to do this today is with strips of wood cut to the same size as the ribs & then use bricks to hold the vinyl in place until the glue has set. Of course the sunken ribs just serve to catch dust & crud, but who are we to argue with Bertone's genius.
The dashboards were always body colour and after '55 the dash tops were satin black, this cage way to the removable vinyl dash top circa mid '58. The inside of the instrument pod is satin black to reduce glare.
Keep checking the pictures of 06481 for comparison.
Ciao
Greig
  #45 (permalink)
Old 09-14-2009, 06:08 AM
Member
Search "front brake adjuster/cam" for photos(with brief captions) of the cams and what I did to repair mine.Also,in photo #20 of the backplate,you'll see a slotted screw w/ jamnut.That adjusts the shoe to be parallel with the drum so you get full contact across the shoe. Your Bosch distributor(much like the VW 36HP) does have two centrifical advance weights and springs under the pointplate.FWIW,I'm using this distributor in my 61' spider normale with a Pertronix 1849 kit in place of the points,and it runs well.It takes some filing to get this kit installed,but in my opinion,it's worth it.Hope this helps,Phil Lawrenceville,Ga.
