Old 07-07-2009, 07:22 AM
Gary
For a 1963 Giulia Spider 1600 what sources are there for the foillowing:
1) Back up light switch
2) Rebound straps for rear
3) Sending unit water temp
Old 07-07-2009, 10:07 AM
ClassicAlfa in the UK
Stuart
Old 07-07-2009, 03:21 PM
Gordon Raymond's Avatar
In the US, Centerline, IAP, and APE (Alfa parts exchange in Calif.) Stuart has also given you a UK contact, depending on where you are located, Christian Ondrak @OK parts in Germany is also excellent.
WELCOME TO THE BB!
You can find any information or help you may need from willing and helpful BB members.
Gordon Raymond
Old 07-07-2009, 04:16 PM
Gary
Thanks for the response. I also have a problem with the right front brake locking up when first applying pressure in approaching a stop then backing off and reapplying the right front will brake real hard. I'm sort of doing a slow pump of the brakre pedel. A broken return spring? soaked brake lining? It's a all drum Guilia.
Old 07-07-2009, 04:34 PM
Your diagnosis seems likely Gary, Time to pull that front drum and have a look in there. The Alfa drums, functioning correctly, are great brakes with excellent pedal feel and more than enough stopping power for the weight of the car. Fortunately, from the sources listed, just about every part you may need for a complete restoration of the system is available.
Gordon Raymond
Old 07-07-2009, 04:40 PM
gary
They are beautiful drums as I have cleaned them up to a nice shine. Now, I'll check more closley inside. Thanks.
