Old 05-29-2009, 01:30 PM
NMS's Avatar
NMS NMS is offline
Member
Hood "intake" on Giulia Spider
On my 1964 Giulia Spider, the air intake on the engine hood, is now just an opening (with the chrome decoration), not blocked. I got a hood mat to glue on the inside of the hood, and realized that water will get between the hood and the mat (not good...).
How is this prevented? Is the block out panel (saw it in the parts book, but not in person) sealed? If not, how is water drained? Anyone know a source for the panel? Is it reasonably easy to make one? Could anyone post some pictures of the arrangment?
Also, is regular contact cement OK for gluing the mat to the hood?
Thanks!
Naftali
Old 05-30-2009, 06:38 AM
lex lex is offline
intake
Hallo,
Just a vinyl sheet glued on the intake holes ('64 spider)
I also find this strange.
The insulation covered everything.
I use classic Pattex (yellow one), the transparant one is not heatresistant.
Make a test before, with your insulation.
groetjes,
lex
Old 05-30-2009, 08:57 AM
Thanks!
Naftali
Naftali,
The block off panel is just a strip of thin steel sheet metal, which you can make yourself (make a pattern using cardboard, then transfer it to sheetmetal). The block off panel should be painted flat black before installation. It is held in place by the three posts on the chrome trim strip, and is sealed all around the opening using a non-hardening material like putty. You could also use silicone sealer since it will not show when the insulation pad is in place. And regular contact cement should work all right for the insulation mat.
62 Giulia Sprint
65 Giulia Spider Veloces (two)
88 Milano 3.0 L
91 Ducati 900 S/S
06 Ducati Paul Smart 1000
Old 05-31-2009, 07:20 AM
concept 101's Avatar
Looks like this:
Dennis
Old 05-31-2009, 11:09 AM
GTD's Avatar
GTD GTD is online now
Naftali
In the interests of anyone reading this thread in the future ... to be as original the opening is blocked by the strip of steel that concept 101 displays ... but the steel is covered with a thin black vinyl which had an equally thin foam layer bonded to it.
When installed this caused the vinyl to be pressed against the inside surface of the hood/bonnet creating a water seal. No putty or sealant was used. The vinyl was semi-gloss or chassis black in color with a smooth surface - no texture.
With the chrome trim installed, the shadowing completed the illusion of depth; it was effective since the vinyl was compressed by the hood and protruded slightly through the openings.
Many Giulia's saw this treatment removed by early owners wishing to make their Alfa "a little different".
Alfista Sapien
Localphone: Cheap International Calls
Old 05-31-2009, 11:31 AM
NMS's Avatar
NMS NMS is offline
Member
Wow! Thanks for all your accurate descriptions and pictures!
I think it won't be too difficult to get it right...
Naftali
Old 05-31-2009, 01:58 PM
Gordon Raymond's Avatar
GTD is dead on correct. Mine is original an has served as a pattern for many cars, but his written description says it all.
Gordon Raymond
Old 06-01-2009, 10:50 AM
Originally Posted by GTD View Post
Naftali
GTD and Gordon,
Even though I've owned Giulia Spiders (3) continuously since '71, I'm never surprised to find new facts about these cars. Although the block off plate was in place on all three hoods, none of them had the vinyl strip in place. I just checked the plate for the '65 Spider Veloce I'm (very slowly) restoring, and can confirm that it is painted chassis black, with no sign at all of any adhesive to hold a vinyl strip in place, and no traces of a vinyl strip. So, I left a note on the plate to add the vinyl strip when the time comes to reassemble the hood. Thanks for sharing this detail
62 Giulia Sprint
88 Milano 3.0 L
91 Ducati 900 S/S
Old 06-01-2009, 12:16 PM
Hi Jim,
The metal strip is painted chassis black under the vinyl and foam. Here is what I discovered. the vinyl is well replaced by 3M Electrical Vinyl tape. The foam is very thin and serves to push the non shiny vinyl into the holes in the hood for both a water tight fit and the illusion of them being real holes.
Gordon Raymond
Old 06-01-2009, 11:41 PM
pathung's Avatar
Black is Faster...
Does anyone have a photo of the plate with the vinyl still on it? Mine came without such. Does the vinyl cover the entire plate?
Patrick Hung
'59 Giulietta Sprint * '63 Giulia Spider * '67 Sprint GT Veloce
Costa Rica & Taiwan SNO Chapter Director
VeloceSpace Restoration Parts
Sprint Racer Build Photos
Vintage Alfa Registers
Old 06-02-2009, 12:49 AM
The vinyl and foam cover the entire plate. The vinyl goes around the ends of the plate and these flaps are captured under the end nuts that hold the chrome and backing plate in place.
Gordon Raymond
