Old 05-27-2009, 08:56 AM
limiter straps
HI ,quik question. are the axle liniter straps for 101 spiders the same size and length as the 750 spiders?
Old 05-27-2009, 01:57 PM
Yes. Make that yes, but . . .
Berlina straps are longer than Sprint/Spider straps and the last set I bought turned out to be Berlina straps. Try them full length. If the axle tube hits the exhaust at full droop, or if the ball joint in the triangle runs out of travel, then you will need to shorten them a bit.
