Dennis,
Hopefully it all went well for you. If you haven 't started. I will post how I did the job yesterday on my car.
First, I noticed I had two different chrome strips on my cars. The one origenally on my car had small corners cut out where it would meet the posts (like 5 by 5 mm) which made the fitting easier, I believe that this was original as the cuts were perfect in its original chrome, so I do not believe this was done later. On my second car the strip was ended by a straight cut. I was lucky to have the old rubbers with the car, which I first installed with the posts. Then I assessed how the best fit would be and I decided it would be best if I would keep the rubber 3 mm longer than the strip (following the cut out bit). Then I prepared the rubber for the posts. By cutting it . Unlike Stuart, I did not cut of the lower part of the rubber where it fits horizontally, this resulted in the rubber being a little bit higher on the interior site of the car 5-6 mm.
First I installed the posts ,not firm so I could still move them, and then I installed the rubber and chrome strip to the car. I installed the top chrome and rubber to the window and installed it on the car placed the top bar in its place by moving the post a little bit and then placed the rubber in the post one by one, as I let the top bar in place as much as I could, I had to unscrew it when I installed the post rubber.
All in all I am happy with it really only very small gaps left and it looks as good as on my 2000 Touring that has a similar window and rubbers on it.
Regards,
Jelle
