#31 (permalink)
Old 05-19-2009, 01:38 PM
morelisse's Avatar
Originally Posted by Brad750f View Post
I am at the same point of completion that Jorg was when this thread started. My question is, how mach of the 101 1300, and 1600 detail shown here is applicable to 750 Spiders?
I'm interested in the rear panel insulation dimensions, and material, as well as what goes under the mats.
Thank you to all contributors, this thread is a great record for those putting Giulietta's back together.
Regards, Brad Baum
Escondido, Ca
Hi there Brad, it's obvious I can't help you out, but good luck putting yours together.
Greetings, Jorg Morelisse
  #32 (permalink)
Old 05-19-2009, 03:27 PM
Gordon Raymond's Avatar
ASK GEORGE Kraus what he put under that rear rubber mat. I really does not matter too much unless it needs be 100% authentic. Bob Hoy has used a special sound deadening mat in his car. Won't absorb moisture, and is a modern solution.
Gordon Raymond
  #33 (permalink)
Old 05-19-2009, 10:22 PM
Junior Member
Thanks Gordon, I agree with your insight. I should have been more to the point though. I've placed an order with the well known restoration supplier in Houston. They said they don't have a patern currently for the rear bulkhead covering, and would I mind sending my old one. My wonderful little car arrived from Florida 18 months ago completely stripped down and I don't have a pattern for Matt to work from.
All the best, Brad
  #34 (permalink)
Old 05-19-2009, 11:08 PM
Ah! Another easy one! Get some brown paper bag material at a Kinko's or other package supply outfit and make up a pattern. The whole area to the trunk bulkhead is covered, including underneath the spare. IF you have the rubber mat, the insulation pattern is the same. I believe Matt sells the rubber for the area. If he has any in stock, the insulation pattern follows. Only the top surface is covered with the silver under-hood type fabric. No stitching, just lots of "Alfa glue" holds the fabric to the insulation. More "Alfa glue" holds the insulation to the rear spare area. Should be pretty simple Brad.
Gordon Raymond
  #35 (permalink)
Old 05-29-2009, 01:47 AM
morelisse's Avatar
Again a little question concerning the vinyl.
Is there any padding under the vinyl? Or is the vinyl glued directly onto the metal?
As is can see in George's pics it looks like the vinyl under the seats have sounddeadening under it, but how about the part on which the sparetireclamp is mounted?
all in all it's harder than I thought
  #36 (permalink)
Old 05-29-2009, 09:25 AM
In production, the vinyl was glued with PLENTY of Alfa Glue to the painted metal floor, and spare hold down bracket.
Gordon Raymond
  #37 (permalink)
Old 05-29-2009, 12:06 PM
morelisse's Avatar
Thanks Gordon, you are again of great help! I like the way you keep referring to the use of ALFA GLUE
Have you seen my thread about getting the car started? Any ideas?
