Or, if you are lucky, your 4 speed rear casing will already have the the recess for the layshaft extension machined into it so you can fit a new bearing (standard SKF) and put the 5th speed cluster into the 4 speed, without changing the cross member. Depends on how much you want to keep it looking original.
Simon
101 Spider, 105 Berlina (x2), 156 2.5 V6, Fiat 125, Mini 1000
