04-21-2009, 01:52 PM
How was the oil? I hope not too hot!
 Gordon Raymond
04-21-2009, 02:55 PM
I did as suggested and my tach still bounces untill it hits 4k. When I pulled the cable out it looked pretty good? Does this mean I need a new cable?
Greg ~ 1959 Alfa Romeo Giulietta Spider Veloce 750F
48000 orig. miles, this car was purchase by my father in 1962
04-21-2009, 03:42 PM
This is reasonably common with the older Alfa gauges. It might mean that the gauge, like a watch, needs disassembly and cleaning by Palo Alto Speedometer. Give them a call and get an opinion. OR, you could try replacing the cable. In my experience, when they jump around, and you check the cable sheath for kinks or binds, and clean and lubricate it, if it still jumps around, or worse, makes noises (!) it's the gauge itself.
 Gordon Raymond
04-21-2009, 05:35 PM
Membro Maggiore
Can you try to spin the tach with something external like a drill motor and see if it bounces without the cable? If no, maybe it is the sheath, not the cable, as suggested by Gordon.
Larry
Hartselle, AL
Director, Alabama Branch, SNO
Help for the Confused and Incorrect since 2009
When men such as Captain Larry absconded to the Florida Keys, they left behind a myriad of tall tales and unbelievable stories.
04-21-2009, 05:48 PM
Hey, good idea... Thanks!
04-21-2009, 08:02 PM
Wouldn't do that. It's likely to damage the gauge as a drill has way too much torque and its speed is not easily controlled. Ask me how I know this.
04-21-2009, 08:12 PM
I understand Don! I've a real nice 3/8 Milwaukee variable / reversing / hammer drill.
I have used it for such tests. v e r r y c a r e f u l l y.
Otherwise, "zip bang", instant junk!
 Gordon Raymond
04-21-2009, 08:22 PM
Membro Maggiore
Are you guys saying .... shudder.... I am confused and incorrect??
Larry
Hartselle, AL
04-21-2009, 08:26 PM
Absolutely not, Larry, You are clearly v e r r y c a r e f u l, while I AM confused and incorrect.
 Gordon Raymond
04-21-2009, 08:29 PM
Membro Maggiore
Whew!
Ok I'd say to cut down on power/torque use a Dremel tool, but I don't think the tach would like the 20,000 rpm either. A Mazda tach maybe (there is a story).
Larry
Hartselle, AL
04-21-2009, 08:38 PM
Zoom-Zoom ..... BANG!!
 Gordon Raymond
04-21-2009, 09:22 PM
Membro Maggiore
Exactly!
how did you know? that happened at TWS in .. must have been 1985!
Larry
Hartselle, AL
04-21-2009, 09:47 PM
Exactly!
Speedometer or tachometer run up with a Dremil tool. From a SAFE distance!
 Gordon Raymond
04-21-2009, 10:00 PM
Membro Maggiore
I don't recall this much shrapnel. I was standing right next to it.
But it does appear to be a picture of the aforementioned Mazda mishap. Probably why I have no eyebrows now.
Larry
Hartselle, AL
04-28-2009, 06:58 PM
This ended up being the gauge, I took it apart and the disk inside was rubbing. I shimmed it out a little and all is good now. No gears inside the tach to strip with a drill, the speedo may be a diffrent story through. Thanks for the support!
