Old 11-01-2008, 07:14 PM
Wanted Girling disk brake Pistons
Hi Everyone, I just thought I would ask if anyone had a set of Girling caliper pistons for my 65 Veloce spyder.. each brake has one large piston and two small... also what would be a fair price for these...thanks John
Old 11-01-2008, 10:19 PM
velocedoc's Avatar
Try your vintage Volvo supplier. I understand they came on the same period brakes for the Volvo's. Not sure if it was the S series or the P1800's. they will know. Just be sure to give them the diameter of the puck. When you get the kit, put lots of silicone grease under the dust cover to help retard moisture as this is what kills the pistons. The pistons rust up and freeze in the bore. This was also the reason why the early 105 production cars that had Dunlops installed on the assembly line, went over to ATE in the mid 1967 year production was due to frozen brakes.
The Volvo P1800 is the most common car with the same Girling 12.5 lb.
caliper as the Spiders. As Van said, Don Thibault at P1800.com | 508-888-9715 has
stainless pistons available and may have some rebuilt caliper units
too.
This information came from the 750-101 discussion group.
Christopher ...working on Alfa's since 1970.
Spider Veloce/Sprint Veloce/Sprint Speciale Registers
1965 Spider Veloce (Bestia)
1967 Giulia Super (Julius)
1971 1750 GTV (Alfie)
1976 Spider (Lola)
1994 QV -#34/35 - Black (Nero)
1995 QV #29/95 -Arctic White (Bianca) 164Q Register N. America
164Q #34 and #63 of 130 total imported
Old 11-02-2008, 01:21 PM
Za-gato's Avatar
Member
Caliper pistons set @Alfa Stop UK
If needed you also have Alfa Stop UK selling these pistons. Tony has individual pistons as well as a set of all 6.
I have bought one set and they are well made and works great.
Alfa Romeo car parts from AlfaStop: Brakes, Suspensions, Transmissions, Exhausts.
Best Wishes,
Joakim
Old 11-02-2008, 05:13 PM
Thanks for all the great help and information...John Gallo
Old 11-03-2008, 06:10 AM
cstlhn's Avatar
John,
There is a supplier in Brewster, NY called Custom Spares. He stocks Stainless Steel pistons in many sizes. You should measure yours before you call.
David
______________________
1959 101 Sprint
Old 11-05-2008, 06:19 PM
Hi david,
Would you happen to know the name of the supplier in New York...thanks John
Old 11-05-2008, 06:42 PM
cstlhn's Avatar
Custom Spares, Ltd.
845-279-7300
Buona fortuna, David
1959 101 Sprint
Old 11-07-2008, 03:45 PM
Thanks David ...i will contact them..choe
