Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > Giulietta & Giulia (1954-65)
  #16 (permalink)
Old 10-28-2005, 05:34 AM
AlfistiSA's Avatar
AlfistiSA AlfistiSA is offline
Decal
Hmmm, we have more in common than we thought..........
I seem to recall the decal on the box of my '64 Guilia Sprint GT (g.d.) being yellow too
Ciao
G
  #17 (permalink)
Old 10-28-2005, 12:45 PM
Elio Comello Elio Comello is offline
Hi 65 Giulia,
Check out http://www.redlineoil.com/whitePaper/13.pdf
This is what I'd use in your situation, regardless of the synchros, you might have.
Elio
  #18 (permalink)
Old 10-31-2005, 07:45 AM
kengta's Avatar
kengta kengta is offline
Here are some pictures of some earlier non-moly synchro parts compared to later Moly parts. I could not find an example of a Non-moly Sleeve but I think they did not have a groove on either side.
Note that the moly sleeves from the late 60's and early 70's, at lease, have a goove on one side only.
I have a later trans from a GTV 2000 that has no grooves on the either side of the synchro sleeve.
So I think Alfa placed these grooves to differenciate the parts at the time of introduction of the the moly type transmissions.
FWIW
Regards
Ken
Ken Geiger, Toronto
1965 GTA, RHD, Corsa, Trans/Am 66-72
1966 Sprint GT, B-Sedan in 70's
1970 Giulia Super (CDN Spec)
1976 1600 GTj (Italian Spec)
  #19 (permalink)
Old 10-31-2005, 04:45 PM
Alex's Avatar
Alex Alex is offline
I love this BB .................
  #20 (permalink)
Old 10-20-2007, 02:30 PM
ecdysiast ecdysiast is offline
Ken,
Two years ago you posted a pdf of a tech bulletin concerning moly v non-moly transmission oils. Apparently that pdf is no longer available on the alfa bb--at least it doesn't come up for me. Could you send it to me, if you could find it?
Jeffrey Frey
ecdysiast1@gmail.com
  #21 (permalink)
Old 10-20-2007, 04:03 PM
Andrew Andrew is offline
What a fortuitous thread. I have this exact question re my new 61 101 Spider Veloce. Its trans was rebuilt several times, last in the 80s, but I don't know what synchros were used. I have both Dentax and modern oils.
Ken, the attached images above of the synchro surface aren't showing up for me. Are they still posted?
So:
grooves on both sides=pre-Moly, use Dentax
smooth looking but rough feeling surface=moly, use Spirax or modern EP
Not sure how much I'm going to be able to tell by peering in through the filler or drain holes.
Andrew
