Old 07-25-2009, 10:45 AM
kengta's Avatar
Sliding Block Rear Suspention Castings-New Repro
Hi All,
I am doing some other work with my foundryman and will investigate the possibility of casting some sets of the 3 sliding block castings in aluminum alloy A356, straightening them and having them heat treated to spec T6;
If there is interest that turns into committed interest prior to casting.
I cannot offer machining.
I have done this process previously and those castings were successfully machined, combined with the other manufactured parts, mounted and raced on a GTV. I have original dimensions and specs for the other material requirements and for suitable rod ends and shoulder bolts, etc.
The patterns are original Autodelta parts doctored to allow for machining and shrinkage of the new castings but as such will vary from the originals, for the most part, at the extremities. The pictures show the patterns. The red areas denote surfaces to be machined and are built up for that reason. In a previous casting run the AUTODELTA script reproduced nicely. The web on the right side of the U-section is for stiffness during casting and heat treatment and is completely machined away in the finished product per the original.
Some of you may want to consider the cross piece alone for your panhard rod or watts link set up.
Given any interest I will work up a price.
Ciao
Ken
Ken Geiger, Toronto
1965 GTA, RHD, Corsa, Trans/Am 66-72
1970 Giulia Super (CDN Spec)
1976 1600 GTj (Italian Spec)
1977 BMW R100S
1985 Beneteau First 29
Old 07-26-2009, 05:41 AM
Blue Flame's Avatar
Hi Ken
I'm interested in a cross piece (mine has been welded) certainly and the other two pieces to boot. PM with details if you will.
Old 07-26-2009, 08:23 AM
kengta's Avatar
Originally Posted by Blue Flame View Post
Hi Ken
Hi, Yeah, one of mine has been broken and welded up as well, The A356 alloy is easily welded for a good strong repair.
If I have enough interest I will post details when I've done all my home work. Just got the idea yesterday.
Ciao
Ken
Ken Geiger, Toronto
1977 BMW R100S
Old 07-26-2009, 09:56 AM
Hello interested parties,
Why reproduce these items? Have you taken into consideration all the macining required to complete these items?
I do have some spare items. Find attached photographs of the items available. I do not have spare 'chassis cross members' and that is all you would have to reproduce.
Old 07-26-2009, 11:55 AM
kengta's Avatar
You are correct there is a lot of machining of the 3 castings and fabrication of several other parts as well. I'm just trying to help the community here, as you are, before I strip the patterns back to their original surfaces. Don't really need the work involved.
Ciao
Ken
Ken Geiger, Toronto
1977 BMW R100S
Old 07-28-2009, 10:01 AM
South Africa,
Could you please send me a PM with the costs etc. Thanks
Stuart
Old 07-29-2009, 11:02 AM
kengta's Avatar
Repro Sliding Block Differential Casting
I've had question about the possibility of reproducing the sliding block differential casting.
While this could be done using an adjusted original as a pattern, in this case at least 2 core block patterns would also have to be accurately made and the following machining required extensive and very precise. I would say much more so than the other 3 castings as the final gear and axel alignment is critical.
The actual casting would likely prove to be a small part of the equation. Having the core blocks made by a pattern maker would be a significant one off cost. The machining of the bearing carriers, a steel insert to carry the inner pinion bearing, axel housing mounting flanges and the bottom cover surface would be time consuming unless there was a large enough order to justify the set up and any special tooling.
I doubt there is sufficient demand to justify pursuing this further.
I have had a look at both types of diff castings and there are other differences mostly in the webbing reinforcements and of course in the location of the oil in hole and the addition of the pin plate mount. See the side by side comparion in the attached photos. The SB diff house on the left came with GTA 752507 with Dunlop axel tubes and coarse splines and the standard housing on right is NOS.
FWIW
Ken
Ken Geiger, Toronto
1977 BMW R100S
Old 08-14-2009, 04:07 PM
charlino.1's Avatar
Dear South Africa,
I might be interested in installing this rear suspension on my Giulia Gt 1300 Junior.
how much would cost the spare parts?
are they new or are they a recreation?
thanks
charlino.1
Old 08-15-2009, 04:34 AM
ken
thats some fantastic reference material your posting up.
what about casting the deep fin diff sump that are found on montreal? where some of the later gta/gtam cars equipped with them
cheers
db
Old 08-15-2009, 05:58 AM
Ken,
Sorry for the Hi-Jack....I have a 105 rear end that has been modified to run in the sliding block braces. It has a 5.12 R&P and the O.S.Giken lsd that is sitting on a shelf gathering dust. Somebody could buy your castings and my rear end and be up and running.
Old 08-17-2009, 07:45 AM
kengta's Avatar
Originally Posted by andyb6 View Post
Ken,
Hi Andy, is that the axel that you got with #39 69 GTV racer? What are you using in her now and what of the Repro Sliding Block Suspension parts that I think you also got. Did it fail in any way?
Ciao
Ken
Ken Geiger, Toronto
1977 BMW R100S
Old 08-17-2009, 08:36 AM
kengta's Avatar
Originally Posted by davbert View Post
ken
cheers
db
hi db, There were some of these available a while back in Repro from a supplier. Don't know the current status however.
A more complicated casting that what I have been producing as it would require a core to create the interior cavity.
ciao
Ken
Ken Geiger, Toronto
1977 BMW R100S
Old 08-28-2009, 09:36 AM
kengta's Avatar
Alternate alloy possibility
I have spoken with one unenthusiastic heat treater about treating the repro SB parts from Alloy A356 to T6 as I believe were the original AD parts based on assays I did. He was driving me away with the cost. A356 must be first solution annealed and quenched and then heat treated, 2 steps
My foundry man is suggesting a room temperature self aging alloy known as Tenzaloy 713.
It is said to be a good substitute for the heat treatable alloys for large castings that are not easily treated.
Attached are data sheets for both alloys and they have quite comparable properties.
Any Technical opinions welcomed and those interested in such parts your thoughts.
Ciao
Ken
Ken Geiger, Toronto
1977 BMW R100S
  #14 (permalink)
Old 08-28-2009, 12:02 PM
Ciao
Ken
My pieces are still in there. I made up another 115 axle like this one with a 4.78 r&p that works better for the tracks I run.
  #15 (permalink)
Old 09-13-2009, 10:07 AM
Dave Anderson's Avatar
Sliding Block Info
Perhaps a more economical solution and alternative to casting a whole new differential housing would be a cast aluminum piece that would be welded to the back and wrap around the side of a stock housing. We could mill off the rear strengthening webs at the appropriate angle (88 degrees) and a portion of the side webs where the new cast aluminum piece would be welded in. This would be much neater than welding pieces of aluminum between the webs like I have seen done.
For the differential lube filler hole, we would either drill and tap one into the aluminum or make a smaller hole for a pipe plug in the left axle tube.
Dave Anderson
[SIGPIC][/SIGPIC]
