Old 06-26-2009, 12:51 PM
fantombiker fantombiker is offline
recommend me tyres for gtam
what are the best tyres to go on a 13" wheel for a fast road/trackday gtam replica?
Old 06-26-2009, 01:28 PM
Alleggerita's Avatar
Alleggerita Alleggerita is offline
Probably depends where and in what class you run: Avon has several 13" race radials, Hoosier has some 13" radials, Toyo R888's, and Michelin TB5 and TB 15's, and finally Dunlop Racing bias-ply. There may be a few more. Cost and local availability are probably the main issues.
Old 06-27-2009, 09:49 PM
dretceterini's Avatar
dretceterini dretceterini is offline
Banned
It's not going to be real easy to find a great performace tire in 13" unless you go to a full racing tire...
Old 06-28-2009, 04:28 PM
stians's Avatar
stians stians is offline
If you're after Dot-approved tyres i don't think there are better choices than Avon ACB10 (I use them on my race GTAm replica with great success - 245/45/13"), try medium, not soft.
There ar ofcourse Hoosier "Dot" approved tyres...we are not allowed using them in our series, but I guess thery're awesome....rediculous as dot-tyres, but anyways...
The Toyo R888 are out of production in 225/45/13"
In semi-slicks there are unfortunately not much choice anymore. Good luck, and go for the Avons, you will not regret
Regards
Stian S, Oslo, Norway
Alfa Romeo GT1300 -2litre 1967
Alfa Romeo GTAm Replika - 1750 1969
Old 06-29-2009, 01:08 AM
Federico's Avatar
Federico Federico is offline
Try to source Yokohama R352 in the sizes 215/50-13 (front) and 235/50-13 (rear) en mount the open white letters on the inside. That's a good alternative, although short in supply. Does work well as road tires!
Old 06-29-2009, 08:13 AM
Markus N.'s Avatar
Markus N. Markus N. is offline
Tyres
Hi everybody,
We use yokohama 205-60-13 A048
one set in medium for dry
one set in soft for wet and cold
and one set of 205-60-13 Avon CR28 sport for heavy rain!!
Every tyre on 8X13 Wheels made by compomotive!
regards
Markus
Old 06-29-2009, 08:18 AM
Markus N.'s Avatar
yokohama a048
Or here at spa during the Egons 500 with Yokohama A048
regards
Markus
Old 06-29-2009, 08:40 AM
stians's Avatar
Hi Markus
Do you use spacers on those Compomotives to get them this far out? I use som cheap 8x13" wheels from Bassett Racing with 245/45/13" tyres. Those wheels have 2" backspace (err...at least I think that was the case) and almost touches the arches (it would have if I did'nt hav 2,5 degrees neg. camber). I am looking for something new with slightly more margin. BTW: have you tried wider tyres than 205's?
Regards
Stian
Old 06-29-2009, 08:55 AM
Markus N.'s Avatar
Hi Stian,
Yes I use spacers on the wheels. 25mm per side!
In the front the brakedisc is direct in the wind, you will have no problems
with hot brakes.
I only can use the yokohame 205-60-13 because we need to have 10cm space to the street (Hist.app. K)
regards
Markus
Old 07-02-2009, 01:52 PM
HZBGTAM's Avatar
HZBGTAM HZBGTAM is offline
Hi Markus,
Have you any steering box issue with the 25 mm spacers.
I had a burmann box failure but my car is with 9 x 13 wheels and I have limited now the front spacer to 10 mm.
At the rear axle, do you have longer studs to fit a 25 mm spacer or what type of spacer did you fit.
My car was when I bought it, fitted with AVON ACB10 but 245.45 x 13 front and rear and was not manageable on normal road. I fit on the front Yoko R352 in 215/50 x 13 and ZF steering box. Driving control is fairly better but I think to drop to 205/60 x13 if it fits on my big wheels. I think that if I had the choice, size 8 x 13 must be the better for the front to solve all the issues.
I want to be able to use my car on road and sometimes for fun on tracks
