Dear Andrew,
I attach the brochure that we have prepared for the GearBox (sorry for my english, may be there are some terms that are not correct):
ALFA ROMEO GIULIA SERIES 105
FRONT COUPLING GEAR BOX,
LA OFFICINA PATENT
We are proud to present you the new gear box developed and patented by Laofficinas' Technicians
This new evolution consists in a front connecting coupling gears, able to guarantee high racing performances, and, at the same time, an easy driving comfort as a traditional gear box.
The gear box project uses different sliding gears and sliding sleeves that can be installed on any traditional Alfa Romeo 105 series gearbox , as well as on racing gearbox with tight gear ratio
The main difference of this gear system (both for racing as for traditional street gearbox) consists in the fact that you can use it as a sequential gear box where you can change the gears without using the clutch in acceleration or downshifting and even without lifting the foot from the gas pedal. This permits a drastic reduction of time shifting and save precious time during one racing lap.
The Gear Box is available in two different options
1)
Racing Gear Box complete with Front Coupling and Close gear ratios (picture n 1)
Complete set with total replacing of the following parts (cost ex Works - 6.000€):
1st gear (2,33)
2nd gear (1,57)
3rd gear (1,20)
Drive-shaft 4th gear (1,00)
5th gear (0,88)
Double gear 3rd-4th gear
Double gear 5th-reverse gear
Sliding sleeves ( 3 pieces)
Sliding copuplings ( 3 pieces)
Bushing cage 1st gear
Bushing cage 5th gear
Coupling flange on 5th gear (5 pieces)
Main Shaft
Rolling cages set
We will check the conditions of your parts that are supposed not to be changed. In case of worn-out parts, we will replace them with original standard spare parts.
The kit has a close gear ratio of gears :1st(2,33), 2nd (1,57) , 3rd ( 1,20) , 4th ( 1,00) and 5th ( 0,88) , that we have specially developed for racing competition (see the speed/rpm chart).
On demand we can also supply :
Racing differential with variable set up in acceleration and braking
Light double disk (140 mm.) clutch kit with racing light fly-wheel (total set is 5,5 kg – see the pics)
This Gear system can be used for a normal street use as well as racing track experience.
You won't feel any big difference with the original gear box.
In case of overhaul due to syncro worn out you can change only the single parts as sliding gears or sleeves rings or front coupling gear set, halved the price of the gear overhaul.
You go on using the gears, so you reduce the costs and the handwork.
The special alloy and hardness of the materials used in this kit permit a double working life and efficiency of the gears, so the overhaul will be done much later than the use of original synchro mechanism even in racing gears box.
2)
Front sliding Coupling assembly suitable for standard or racing gear boxes already assembled (picture n 2)
This second option supply only the front sliding coupling, the sliding sleeves and the sliding gears that are mounted in a standard or racing Alfa Romeo gear box (cost ex Works - 3.000€).
The original gears of your gear box or the racing ratios remain, we only substitute the following parts with our special ones:
Set of 5 pieces : flanges inserted on the gear
Set of 3 pieces : sliding couplings
Set of 3 pieces : sliding sleeves
In case of overhaul the new components replace the original synchro hubs and rings, maintaining the same gears usually used.
This kit can be used by all those that desire to have the same advantages of a semi sequential gear box, and want to exploit the performances of the new system, expressly planned by our technicians.
For both options ( 1 or 2) our experts can fix personally the gears components on your own gear box.
To see the demonstration or proof of how it works, visit
YouTube - Broadcast Yourself. typing “laofficina gear box” or
If you are interested please do not hesitate to contact us
Attached Pics:
Complete Racing Gear Box (Picture n 1)
Kit Front sliding Coupling (Picture n 2)
Special Light Racing Flywheel (5,5 Kg. Including klutch kit)
in the picture is shown the GTAJ 1300 flywheel – available also for 1600, 1750 and 2000 cc.
Gear Box Speed Chart (59cm. Tyre diam) with 8/41 and 9/41
