04-05-2008, 06:37 AM
Richard Jemison
LSD/Axles
Copying this as this group might find this helpful..
If you are working on a 105 type car the simple solution is to just swap out a 115 complete diff assembly, as all the mounting bolts & hardware are similar and in the same location on the axles.
BUT, for you few enquiring minds:
The 115 LSD unit can be modified to fit into all the other rear end configurations. The 750, 101, and 105 series. Using the original housungs ring gears (for the GTA hard to find ratios)
I won`t tell you how but there are pics at :Install of a 2 L Into The Giulietta Spider
It requires having the right machinist, metalurgist, and fabricator
As well the GTA splined axles can be built from the common 105 or later 115 large diameter axle.
Richard Jemison
RJR Racing
http://scuderiagiallo.com
04-08-2008, 08:47 AM
true, but all pretty out of date now! Direct fitment competition type LSD units are available to fit both non LSD 105 axles and to upgrade from ZF unit in 2000 axles. Advantages are great weight savings over 2000 GTV unit retro fitment and far superior operation with variable ramp angles and better friction materials which are more durable etc.....
www.alfaholics.com
1966 2.0 Sprint GT race car, 1967 T/S GTA Replica, 1965 FIA App.K 1600 GTA, 1965 1600 GTA Stradale RHD, 1965 1600 GTA Stradale LHD, 1966 1600 Giulia GTC, 1991 S4 Spider, 1967 1600 Duetto, 1999 2.0 916GTV (soon to be sold!) and now replaced with 2002 3.0 V6 24v 916 GTV
04-08-2008, 12:35 PM
You must have financial resources!
Max,
Disadvantages for us yanks is (!!!  ) cost of these components, and a non authentic appearance for our vintage racing. Guess if I wanted to I could put an entire aluminum axle from a dirt track outlaw car under there as well. Golly  , I would have quick change gear sets, and any kind of adjustable LS, MUCH less weight, and an axle that would take 500 or 600 Hp, plus available parts! This would probably be somewhat costly as well. I LIKE  RJ's solution, though I suppose if you work for Alfaholics, you might get these bits at less cost, with no shipping or import duty. I think it's all relative to what you need to do, and what you can AFFORD  to spend. I'm sure you would agree  . Just my opinion.  Gordon Raymond
04-08-2008, 01:24 PM
Director BC Chapter SNO
While I have yet to do some aggressive driving with Rj's work on the diff in my Spider, it seems a reasonable set up for street use.
About 2.5 lbs of inertia was machined off the ring gear, and then there is the anachronism of a 1962 Giulietta that for some weird reason had 750 axles, having --carbon fiber--LSD discs.
1962 Giulietta Spider: Graphite Grey/red; "Tuned" 2L.
1993 Subaru Legacy Turbo Wagon(200 whp).
04-08-2008, 03:31 PM
Richard Jemison
Better LSD? Out of Date??
Max, I realize you are selling the "Not out of date" unit.
But in reality isn`t your`s nothing than a ZF modification?
Changing the leading ramp angle has been done since the `late 60s when the first ZF "Lok-O-Matic" units were available to us.
It is a simple machining process to reduce the leading ramp a few degrees to get more lock under acceleration. Few have it done simply because a correctly assembled stock ramp ZF with 4 properly prepared clutch disk & plates are more than adequate for Alfa`s racing today.
The GT2 car had biased ramp angles, stock (4) ZF clutch disk, and adequately handled the 300+ HP with no failures. The unit with stock ramp angles handled it perfectly as well. There were reasons for going back to stock ramp angles for acceleration, the harder locked units caused more push on corner exit.
The ZF unit from 115 series machined to fit the small ring gear and narrower cases for 750/101/105 cars loses about 2.5 pounds, the ring gears can be lightened, and the use of the smaller axles modified to big splines adds no weight....And that was without attempting to lighten it beyond fittment.
The ZF plates really do not "wear out", they accumulate carbon, usually from poor set up. Or if in decambered axles wearing the internal splines a bit, but still acceptable as replacement of all four is $120.00 .
And I dare say that the replacement clutch disk from Larry (at APE) at $40.00 (USD) each, are a bit less than the price of the ones for the Alfaholics unit. By the way what do replacement disk cost for it?
It is all part of the racing budget,... $500-600 +-(USD) to have a ZF unit modified, $300 +- (USD) for axle modification depending on who does them.
Or about $1500+_ (USD) and international shipping, for a "not out of date" unit.
Your`s may work fine, but the ZFs have been working fine for years! Problem being most current day Alfa "racers" are not aware of options, and proper build concepts.
If it is not listed somewhere for sale then they are unaware of the fabricating options that can be done, and that have worked for the "cognicenti" for years.
I am not putting down your product, just not buying into it, as I know the options...like a re-machined FHI Thorsen to fit the small Alfa diffs
Richard Jemison
RJR Racing
04-08-2008, 03:43 PM
Whats a FHI?
1966 Giulia Sprint GT Veloce
1971 Ford XY GTHO (replica) race car (For sale?)
1982 Suzuki "Bathurst" Katana
1985 Suzuki RG500
1995 Cagiva Mito (race kitted 250 powered)
04-08-2008, 05:39 PM
Originally Posted by Gordon Raymond
Max, Disadvantages for us yanks is (!!!  ) cost of these components, and a non authentic appearance for our vintage racing.  Gordon Raymond
It's great to have options. For now, I am using a rebuilt stock type 2L LSD with 4-discs. But if it doesn't lock up sufficiently, I plan to change the ramp angles. But I also understand those that want to just spend the money and solve the problem with a "Gripper" or "OS Giken" product. Gordon, for what it's worth, these units fit into the stock housings, so there isn't anything "non-authentic" about the appearance.
Erik
04-08-2008, 06:21 PM
Yes, I know Eric, and had one in my hand before I did the same as you, but grafted my 1600 tubes to the 2L center. I still have my GTA 5:13 on my shop shelf, but that one really is too hard and expensive to find and / or make parts for, and that's a fact! My point is in being able to use, as you and I and RJ suggest, easily available components that can be replaced quickly and economically as wear or failure dictates. I'm with you in that options are always better than economic dictates! Gordon Raymond
04-08-2008, 07:09 PM
Gordon, I'm curious how you grafted the 1600 tubes to the 2L center section. Did you just cut and weld the tubes?
Erik
04-08-2008, 09:35 PM
2L LS in older rear axles for track and street.
No Eric I cheated. I thought about this for a year, and how to get the tubes square to the flanges, Exactly the right length and so on. I contacted the best race car fabricator I know, and he said I need to build a jig, it would be costly for just one axle. Talked about it with a friend who told me Jack Beck had just such a jig. I called Jack, and found he had done a bunch for racing. Rather than cut all the stuff off the 105 tubes, and then weld back on all the Giulia spider stuff, he just cut the spider tubes, cut the 2L stuff off the flanges, put them in his jig and after tacking them around, laid in a penetrating bead. His job is 100 % perfect  .
Actually, better than the factory axle. He came up with exactly 1/16 toe in per side, measured from the differential centerline with a laser alignment machine. He probably could have added a little negative camber if I had asked. This allows the use of the common 2L center section, with is many ratio's and any variation of the LS set up one may want for track or street. I carved the aluminum casting outside a bit, to resemble the earlier 1600 center, and to clear my Ausca rear sway bar. Looks right, works great, couldn't be happier  . RJ's modification allows the use of the 1600 casting with 2L internals. Better still, but when I did mine 7 years ago, I wasn't aware Richard could do this work  . He can even use the 2L LS in a 750 center  !!! Very nice fabrication indeed. Subtle, here on the BB, has a tuned 2L in a Giulietta, with this 750 center and 2L, LS by Richard. He is one happy guy!
It's really great that machinists like Jack and Richard can do this stuff for us affordably   .
If this sound like I am promoting Richard and Jack, well  .... I am! The GTA axle in my Ausca spider was pretty limiting for anything other than pure race track work. The 2L LS makes the car street worthy and not just a garage queen. I have no fear of any type failure that requires speciality parts. Having owned my car from new, it's great not to have to worry about parts specific to the GTA unit. I strongly recommend this upgrade to anyone with concerns about their GTA unit, or just for street or track applications with the older rear axle's. Richard and Jack can do the job RIGHT!  Gordon Raymond
04-09-2008, 06:57 AM
Richard Jemison
750/101 to 2L center section
With a proper set up LSD (115 type) axle breakage with smaller diameter axles are almost non existant particularly with low HP/Torque 1300/1600/1800 motors. (less than 170 lbft Tq)
The Keep it simple (no tube cutting) method requires tube flange mods to fit the larger case. As well the LSD unit must be machined to both fit the left tube`s smaller bearings and closer positioning to the RGC.
The axle mods are critical & require correct metalurgical skills. The splines are cut depending on application. All of course to fit the 115 drive recievers, but the taper and even percentage of contact is dependant on the camber and toe desired. Toe and camber should be gained by shrinking the tubes in the correct locations rather than cutting. Done correctly 1 degree negative camber and 1/8 overall toe is easy. With careful build and spline cutting 1.5 degrees is about as much as they seem to live with without frequent inspection.
Below is a 101 tube & axle with 115 center & modified 4 disk LSD Lightened ring gear with 1 degree negative camber and 1/16 toe per side.
On my website are pics of the axle in my Giulietta, which is modified similar to Gordon`s, so that the 115 axles can be used.
If using Drum brakes as on my Giulietta, the spacer between the axle seat and wheel bearing must be changed before pressing on the bearing, so that the drum matches the brake backing plate and centers the shoes correctly. As the 115 wheel/brake mounting flange is located differently.
Richard Jemison
RJR Racing
