Old 04-12-2007, 07:50 PM
James1750's Avatar
James1750 James1750 is offline
Can a GTA Oil Pan fit a standard on a standard 2ltr engine?
Just a quick question (and probably quite stupid one)....
Can a GTA oil pan fit onto a standard 2 litre or 1750 engine?
Just wondering as the GTA oil pans look to have a lower height than standard 2ltr/1750 oil pans and might give a bit more ground clearance (if rolling without a sump guard)......
Thanks for any replies
James
1968 series 1 1750 GTV (RHD)
Old 04-12-2007, 09:03 PM
RossoGTV4Me's Avatar
RossoGTV4Me RossoGTV4Me is offline
I would like to know as well. The neat magesium ones with three rows has a part number in the old AD Perf. Catalouge and says (ALL). Hmm..
I am not sure if the stock GTA pan was the magnesium three row one in the AD catalouge of 77'?
-65" Sprint GT (GTA Replica Race Car Project)
-66" Sprint GT Veloce (Project)
-69" GTAm (Project)
-73" 2000 GTV (Orig. Owner)
-75" Alfetta GT (Rally/Street)
-75" Alfetta Berlina (Rally/Street)
-94" 164 Quadrifoglio (1/35 94" Q's imported to US) (Entertaining Offers) http://www.alfabb.com/bb/forums/164-...t-factory.html
Old 04-12-2007, 09:04 PM
Alleggerita's Avatar
Alleggerita Alleggerita is offline
It will fit the engine no problem. However it will possibly interfere with your track rod - GTA's had a special bent one.
Old 04-12-2007, 10:06 PM
James1750's Avatar
Thanks guys -
did a bit of a google and just saw a nice aluminum one on the Alfaholics website......
I should pose this question to Max banks as he'd know for sure considering he sells them
I'll send him a PM and post his reply
all the best
James
Old 04-12-2007, 10:23 PM
Alfaholics pan is the bottom piece only - it will fit no problem. It's the upper piece with the windage tray that poses a potential problem. For a windage/slosh tray for your upper pan look at this site http://www.paulspruell.com/motorsport/racing/oil.html
Old 04-12-2007, 10:56 PM
James1750's Avatar
cheers Alleggerita - Thanks for the clarification.
That windage tray looks pretty darn good -
Just found this which is pretty much exactly what I was thinking of....
http://www.alfaholics.com/new_produc...nt_201_121.php
James
Old 04-12-2007, 11:00 PM
PSk PSk is offline
Hoon ...
Old 04-13-2007, 12:31 AM
James1750's Avatar
Originally Posted by PSk View Post
Hoon ...
More like Sydney roads ....oh ok you got me!
Do already have a sump guard ..... but did have to hammer a massive ding out of it recently (not much clearance... so was looking for a little more)
James
Old 04-13-2007, 08:11 AM
Andrew Andrew is offline
Doesn't the GTA pan go with a matching deeper oil pump pickup? If that is the case, if you just use a GTA pan without the matching oil pump, your pickup will be higher in the pan, not necessarily a good thing.
Andrew
Old 04-13-2007, 08:42 AM
emr5503 emr5503 is offline
There are 2 GTA mag pans. 28mm Standard depth and deep. The deep pan takes the longer pick up. Both use the windage tray and same upper pan.
Ed
Old 04-14-2007, 06:57 AM
vsharp vsharp is offline
The GTA pan won't increase your clearance at all, rather the opposite I suspect. I'm not sure of the dimension of the A/H one, but it does look deeper than stock. The deep, original 6 horizontal fin GTA ones are about 35mm closer to the ground than stock!
Vin.
