#46 (permalink)
Old 02-23-2006, 05:24 AM
eag eag is offline
@juultje: i've been looking for the aluminium gta center heart for some time, you mention that it is available for euro 250, but where?
thanks!
  #47 (permalink)
Old 02-23-2006, 09:02 AM
Berlinista's Avatar
Berlinista Berlinista is offline
mesh
I have a square metre of the original stuff.......
For the grill a cut back Giulia item!
Pics and stuff next week.
Body seam welded, GTA master brake cilinder (split system!)
Old style Corbeau's, 2.0 Squadra engine, circa 170 Hp. 2.0 Berlina LSD.
Twin spark brake conversion on 1300/1600 uprights, Goodridge brake lines.
35 mm hollow torsion bar up front, with uniballs......
The works!!
  #48 (permalink)
Old 02-23-2006, 12:38 PM
Veep's Avatar
Veep Veep is offline
the promised pics... had some trouble resizing the pics, way too big, but now a little small... try again..
the inside lockmachanism is left hand, the inside pic is the right door. that tab needs a little bending to be perfect. When you compare this with an unmidified mechanism you will see what has to be done. on the pic inside the door you will see the tab is turned to the left.
  #49 (permalink)
Old 02-23-2006, 12:59 PM
turbolarespider turbolarespider is offline
Good pictures, Veep- very informative.
Especailly for those of us who might try to DYI the pusher using parts from a Giulia (don't ask, just dreaming). But the GTA set up I've seen are pricy- know of a reasonalbe source?
IMHO, I think those look better than the stock ones- yet another reason to do it.
Eric
  #50 (permalink)
Old 02-23-2006, 02:35 PM
alfatwincam alfatwincam is offline
GTA door handle convertion
Hi Veep
Thanks for taking the time and clearing up the issue of the fitment of GTA door buttons to lock mechanisim.
  #51 (permalink)
Old 03-08-2006, 11:40 PM
juultje's Avatar
juultje juultje is offline
My front was damaged and now i'm trying to give it the original shape. The top plate was bend. I've managed to get it in shape resonable, but i would like to have the original messurements of the innersection (where the grille is placed). Can someone who has an original front messure the inner parts for me next to the headlights and in the middle. Thx.
I've used the drawing to make the holes for the door knops perfect !
  #52 (permalink)
Old 03-10-2006, 12:06 AM
sono veL.O.ce's Avatar
sono veL.O.ce sono veL.O.ce is offline
cheapo gta buttons...
You might find that some old VW glovebox buttons are pretty close, and available new for about $12
I have no first hand evidence though, and I don't want to be responsible when the purists find out.
[SIZE="1"]'66 [COLOR="Red"]GTV [/COLOR] rolling chassis --- '74 [COLOR=SlateGray]spider[/COLOR](heirloom) --- '64 [COLOR="Silver"]Giulia Ti[/COLOR] --- '74 [COLOR="Blue"]GTV[/COLOR] sold! --- '74 [COLOR=Red]GTV[/COLOR] sold!
'6x DUCATi 250cc cafe racer.[/SIZE]
  #53 (permalink)
Old 03-11-2006, 01:49 PM
Berlinista's Avatar
OK some pics then...
The goal is a cheapo street/trackday car. It's a car I've had for 8 years now, standing still for seven. Most of the welding was done seven years ago, I've progressed a bit since then, but didn't want to do it all again. I wanna DRIVE this summer. So what the heck.. It's gonna be white, cool, and I've already got an 8 point cage lined up that will also find a place. Suspension is mostly Squadra, the front springs are temporary, everything else is cool stuff....
  #54 (permalink)
Old 03-11-2006, 01:54 PM
Berlinista's Avatar
some more...
can't seem to get them smaller.... ??
  #55 (permalink)
Old 03-11-2006, 02:00 PM
I have that same front swaybar! About 1" aluminum tube? Do you know where they came from?
  #56 (permalink)
Old 03-12-2006, 07:20 AM
Berlinista's Avatar
sorry, that's 35 mm hollow steel bar!!!
Goed a few steps above an alu sway bar....
  #57 (permalink)
Old 03-12-2006, 08:43 AM
scottalfa's Avatar
scottalfa scottalfa is offline
sonoveloce:
I have similar sway bar to what you seem to have. About 1" can't remember though, three piece aluminum, square ends, like the red picture. Got it in the late '80s from Shankle.
  #58 (permalink)
Old 04-05-2006, 11:18 PM
juultje's Avatar
So my projectcar is deliverd at the paint shop. They are also going to put new floorpans in in.
  #59 (permalink)
Old 04-06-2006, 10:03 AM
Berlinista's Avatar
why 'they'
why not yourself?
Tell me?
And if not, why didn't you ask me? (for the floorpans)
  #60 (permalink)
Old 04-06-2006, 10:32 AM
juultje's Avatar
Rik i've got a lot of work for customers so the man who does all my paintjobs will do that for me, i do some technical work for his car as well.
You could have done it for me too i know. But i think you are busy yourself and i would have to drive a lot further with the car and then to the painter as well.
