Pulling transmission - Page 12 - Alfa Romeo Bulletin Board & Forums
 3Likes
post #166 of 171 (permalink) Old 04-27-2012, 08:58 PM
Histking's Avatar
Get thread! Something worth mentioning: That heat shield is made of ASBESTOS. Be careful.
Histking is offline
post #167 of 171 (permalink) Old 04-29-2012, 02:55 PM
ARwrench's Avatar
Location: Transplanted from Holland to The Armpit of New Jersey
Post #9..............
“If you can't explain it simply, you don't understand it well enough”
Oo--V--oO There is a fine line between "Hobby" and "Mental Illness".
ARwrench is offline
post #168 of 171 (permalink) Old 05-10-2013, 08:47 AM
Clutch Fork
I may have missed it but I haven't been able to find much about the clutch fork. I am not able to take a picture at the moment but mine seems a bit worn. I am having a real hard time finding a replacement clutch fork. Any suggestions?
samhunt17 is offline
post #169 of 171 (permalink) Old 05-10-2013, 09:35 AM Thread Starter
gadwhite's Avatar
Clutch fork
samhunt 17
I didnt notice any unusual wear on mine, I think as long as your throw-out bearing is replaced( since it takes the abuse) you should be fine. Is it bent, or worn through? I recommend posting a couple of pictures, so that we can take a look.
[B]1985 Spider Veloce (Isabella),[/B]
2015 Honda Accord Hybrid Touring
gadwhite is offline
post #170 of 171 (permalink) Old 05-13-2013, 12:20 PM
Update
Thanks for the quick reply. I was out of town but now that I have returned I am adding a couple pictures of my clutch fork and throw-out bearing. I decided since I was replacing the throw-out bearing and I couldn't find where to buy one that it would be okay to not replace the fork. It did look a little better after cleaning it up. There weren't any cracks and it wasn't bent. Name:  20130511_122813.jpg
(The pictures were taken before cleaning.)
post #171 of 171 (permalink) Old 05-13-2013, 04:25 PM
101/105guy's Avatar
Make sure to remove the fork and inspect the ball mount under it ! These can wear or bend.
If OK, lube the ball and re-install the fork.
'64 Guilia Spider
'67 GTV
'68 Giulia Super
101/105guy is online now
