Diff swap to Guilia Sprint - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 02-17-2017, 09:35 AM Thread Starter
Stavri's Avatar
Anyone know if a 1600 Duetto 9/41 would work in a 1963 1600 Giulia Sprint 1600?
thanks!
1969 Alfa Spider, 1954 Porsche Speedster,
1962 Ferrari 250 GTE, 1962 MGA MKII,2004 BMW M3
Stavri is offline
post #2 of 6 (permalink) Old 02-17-2017, 09:41 AM
Mound Dawg's Avatar
Location: Running through the ruins, all directions wrong.
Yes, should be a straight swap.
We're gonna make you an Alfa you can't refuse.
Mound Dawg is offline
post #3 of 6 (permalink) Old 02-17-2017, 09:52 AM
Alfajay's Avatar
I disagree with Mound Dawg. A 1963 1600 Giulia Sprint 1600 is a 101 series car, while a 1600 Duetto is a 105 series. The 101's have their spring mounts welded to the tops of the axle tubes, while the spring mounts are on the trailing arms of a 105. The trailing arm mounts and attachment for the "T" arm were also changed between the 101 and 105 series.
You can do this conversion by cutting that hardware off your 101 axle assembly, and welding it onto the later axle. But no, it isn't a bolt-in.
'63 Guilia spider
Alfajay is offline
post #4 of 6 (permalink) Old 02-17-2017, 10:10 AM
Mound Dawg's Avatar
He asked about a diff swap and mentioned the crownwheel and pinon size so I assumed that he was looking to put the 9/41 into his Sprint casing not swapping the whole axle or casing over. The exterior fittings are different but the internals are the same.
post #5 of 6 (permalink) Old 02-17-2017, 10:50 AM
Alfajay's Avatar
Ah, I see what you are saying. Yes, I agree that you could swap the 9/41 "guts" from a 105 differential into a 101 housing. You would probably do this if your 101 was a normale with a 5.12 ratio.
But swapping differential internals is difficult. You need to shim the gears in three dimensions and they must be positioned quite accurately to avoid noise and wear. This is not a job for a home mechanic. It is a lot easier to just swap an entire rear axle assembly, even if that requires cutting, welding, adapting.
'63 Guilia spider
Alfajay is offline
post #6 of 6 (permalink) Old 02-17-2017, 11:13 AM Thread Starter
Stavri's Avatar
Thanks. That's what I was looking for.
Steve
Stavri is offline
