no clutcth pedal pressure - Alfa Romeo Bulletin Board & Forums
Old 02-23-2009, 08:54 AM
Clutch pedal has no pressure and resivor is empty filled but did not help?
Old 02-23-2009, 10:23 AM
conedriver's Avatar
George Schweikle
You need to bleed the clutch at the slave cylinder to remove air from the line. You didn't say what kind of Alfa, so it's hard to provide specific bleeding techniques.
George Schweikle
Scuderia Non Originale
Old 02-25-2009, 12:24 PM
ARwrench's Avatar
Bleeding would be a moot issue! Where did the fluid go? New parts needed
Old 03-04-2009, 09:04 AM
gigem75's Avatar
If you havent noticed any fluid leaks where you park it you need to pull the clutch master cylinder off and check that the fluid didn't leak out the rear seal and into the booster.
Old 03-04-2009, 09:53 AM
Alfisto Steve's Avatar
Who's on first what kind of Alfa has problem?
Maybe brake master removal would be a better idea to check brake booster for fluid.
Also would help to know what kind/year of Alfa he is talking about and whether clutch master gets it's fluid from brake reservoir like 164 later GTV6 and Milano or has it's own clutch reservoir like early models GTV6, etc., and my Ranger PU truck?
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Daily drivers: USA models - 91 164L w/AT "Black Beauty I" ALFA4ME; 91 164S Black Beauty II ALFALFA
In 230,000 mile Rehab MY91 "Bianco" 164B 5-speed [My Originale], ALFISTO
Daughter's current ride: Her Granddads 2002 Ford Taurus
Current Car hauler and Parts chaser : 2000 Dodge Ram PU 5.2L V-8
