Oil leak at front of engine - Alfa Romeo Bulletin Board & Forums
post #1 of 8 (permalink) Old 04-21-2017, 06:20 AM Thread Starter
conedriver's Avatar
Has anyone had an issue like this with a nord engine?
I installed a remote oil cooler and oil filter on my '76 Spider, and saw what appeared to be an oil leak at the bottom of the adapter that screws on at the original filter location. Removed adapter, cleaned, new O-ring, but the drips continued. After placing the car on jack stands, running the engine, laying underneath, and looking for the assignable cause, it appeared the oil was coming from above the adapter at the mechanical tachometer drive. Removed the tach.drive, replaced the gasket, but still drips. Replaced the tach. drive seal, still drips, so ran the engine and with some under the car contortion and a mirror, finally saw oil seeping from a water pump stud & nut next to the tach. drive. The oil comes from a small hole in the front engine cover, then into the water pump to the tach. drive gear. I removed the water pump, inspected everything, and replaced with a new gasket and Permatex Ultra-Grey sealant. Upon reflection, it almost seems like there should be an O-ring at the engine cover - water pump joint.
My morning task is to replace the radiator and assorted parts and run the engine - hoping the oil leak has been cured, and my 78 year old back can have a rest....
George Schweikle
Scuderia Non Originale
conedriver is offline
post #2 of 8 (permalink) Old 04-21-2017, 08:25 AM
Gordon Raymond's Avatar
The seal in the tach drive replaced George? I use Viton. There is NO oil pressure at the tack drive / water pump. Splash lubrication.
First photo is viton seal in drive. Second shows big hole for splash oil lube in pump body for tach drive and little hole near drive hole for oil drainback.
NO oil pressure at the pump.
Gordon Raymond
Now:
Gordon Raymond is offline
post #3 of 8 (permalink) Old 04-21-2017, 01:14 PM Thread Starter
conedriver's Avatar
Hi Gordon,
Thanks for the pictures. I also have some spare pieces, and compared these to what is on the car. I replaced the tach drive seal with one from Centerline.
I ran the car for 20 minutes, and the leak is apparently cured. The only difference is that I used a thin water pump gasket last time the engine was apart, and the one I used this time was quite thick; very similar to the ones used for SPICA intake manifolds. But...this shouldn't really make a difference, right?. Maybe the Alfa gods are just testing me
George Schweikle
post #4 of 8 (permalink) Old 04-21-2017, 01:44 PM
The only place the WP gasket wants to leak oil is near that drive, either input hole or the drain back. NOW, it is possible that the little steel rubbing pin INSIDE the tack drive hole in the WP body has fallen out. (Don't ask). If it has, or is AWOL, the drive will leak oil from the WP. Lets see if I can find a picture... Ah, you can almost see the bumper or rubbing pin in the picture below. If it's LOOSE, seal it in with Permetex Ultra grey, under the pin. No more oil leak. If it's GONE (!) find it or another and seal that one in.
Gasket thickness is no matter. Clean surfaces, and gasket sealer are required.
Gordon Raymond
Now:
post #5 of 8 (permalink) Old 04-21-2017, 05:35 PM Thread Starter
conedriver's Avatar
Gordon,
Thanks for the follow-up. I had recently checked the steel rubbing pin and it was tight.
The only scenario that makes sense is that the water pump gasket wasn't installed correctly last year. I originally thought the remote cooler/filter hose connections might be loose, and that's the first thing I worked on before starting on the scenario described in my recent post.
George Schweikle
post #6 of 8 (permalink) Old Yesterday, 04:16 PM
genericwood's Avatar
Guys, I remember several years ago there was a batch of water pumps where the steel pin was installed in the aluminum housing poorly. I had a stubborn leak until someone pointed this out to me. IIRC, I removed the pin and reinstalled with some sealant and the oil leak was cured.
May not have been your problem, but it could save someone else some trouble!
Erik
genericwood is offline
post #7 of 8 (permalink) Old Yesterday, 06:35 PM Thread Starter
conedriver's Avatar
Erik, thanks for the information.
The latest part of the saga relates to a Wes Ingram threaded cam chain sprocket adjuster installed last year during some cylinder head work. This works in addition to the bolt-and-wedge scheme to lock the sprocket in place, but requires the original bolt to be loosened so the threaded adjuster can be used. After chasing the oil leak from the oil cooler hoses, adapter plate, tachometer drive gasket & seal, and finally the water pump gasket, I finally found that the cam sprocket tensioner bolt was missing!. This allowed oil to seep from this hole, down to the bottom of the water pump, and continuing a trail to where I mistakenly thought the leak was occurring. I obviously did not tighten the stock sprocket bolt when I last used the threaded adjuster for the cam chain, so it eventually vibrated out, and I was so convinced the leak was around the bottom of the engine, I neglected to look otherwise . In my defense, that bolt is sort of hidden on the lower front of the cylinder head, and I just kept looking elsewhere. I was in the grip of an "Ide'e Fixe" ("an idea or desire that dominates the mind; an obsession".)
Erik
George Schweikle
post #8 of 8 (permalink) Old Yesterday, 06:42 PM
HA! I love it! Something "simple"!
Gordon Raymond
Now:
Replace with
