NGK B7ES Gap GTV 2000 Spica - Alfa Romeo Bulletin Board & Forums
post #1 of 5 (permalink) Old 08-13-2016, 08:58 PM Thread Starter
Member
Gonzalo Molla's Avatar
Question NGK B7ES Gap GTV 2000 Spica
Hi
I bought a set of NGK B7ES spark plugs for my Alfa Romeo GTV 2000, model 1974 with spica fuel injection, as advised at the alfaholics website.
The car it's ok, with 69.500 miles, but I thinks is too rich on fuel (I need to send my TA from Uruguay to USA ... Not the easiest task).
I had no idea of the gap for the spark plugs!.
Please, could somebody advise me the gap for this spark plugs? It will be ok in mm (in Uruguay we use the metric system)
Thanks in advance
Gonzalo
Gonzalo Molla is offline
post #2 of 5 (permalink) Old 08-14-2016, 05:46 PM
Andrew's Avatar
What kind of ignition? If points, .025 to .028". Not sure what this is in mm, just over .5mm maybe? If electronic ignition, you can open the gap up some.
Andrew
Andrew is online now
post #3 of 5 (permalink) Old 08-14-2016, 06:33 PM Thread Starter
Member
Thanks, everything is standard. Spica injection , points, etc.
post #4 of 5 (permalink) Old 08-15-2016, 07:01 PM
aralfa8589's Avatar
Try .6 mm.
Jeff Lang
'85 GTV6 3L, 73 GTV, '94 164 LS
aralfa8589 is offline
post #5 of 5 (permalink) Old 08-16-2016, 03:09 AM
Bertonemorten's Avatar
Standard NGK factory setting is 0,7.
[FONT="Comic Sans MS"]Morten Svendsen, Rødekro, Denmark
1300 GT Junior 1966 / 1300 Spider 1971[/FONT]
Bertonemorten is offline
Replace with
