I'm a bit confused. In the spare block, will you install the liners matching the old pistions/rings, assuming you can get them out of the block after the pistons are removed, or using the different set of liners already in the spare bock? If it's the latter, at the very least, you'll want to have them honed and checked for spec before use, and if they're OK, I'd spend the $100 for a new set of rings, too.
